#1 TDC & TIMING COVER |
TV 2M8O ![]() Senior Member ![]() ![]() Joined: 20-September-2006 Location: Southern Ohio Status: Offline Points: 1621 |
![]() ![]() ![]() ![]() ![]() Posted: 05-June-2016 at 12:22PM |
Guys,
Been years since I built an engine so I want to make sure my memory is correct... when the marks on the timing gear align, it this TDC on the compression stroke? Need to get everything set so I know where I am when I drop in the distributor. THANKS
Edited by TV 2M8O - 06-June-2016 at 12:52AM |
![]() TV 2M8O OUT JOE 1976 Gran Torino S&H season 2-4 Clone Project Blog: http://tv2m8o.blogspot.com/ |
californiajohnny ![]() Senior Member ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 8664 |
joe, you have the timing cover off looking at the gears? yes! but the TDC mark on the balancer will line up twice TDC compression stroke and again at TDC exhaust stroke
John, yep cover is off and looking at the gears. As I was turning the crank to align the marks, it blew the paper towel plug out of the #1 spark plus hole across the shop so I figured I hadn't forgotten everything!!
Thanks buddy. ![]() |
yep align those marks, without turning it that's the spot to drop in the distributor at your #1 wire location
I also noticed I have a small hole in the timing cover that I think may be a weep hole. It's in a dead passage next to one of the water pump passages. Not sure if it's supposed to be there (it's not a clean round hole) or just a thin spot in the casting I uncovered while blasting it! Irregular shaped and slightly smaller than a pencil eraser....
THANKS
IDK sounds like a "sand pit"
Thanks John, that's what I was thinking too but thought I'd check before filling it in.
Tweet
