  New Posts New Posts RSS Feed - #1 TDC & TIMING COVER
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: #1 TDC & TIMING COVER
    Posted: 05-June-2016 at 12:22PM
Guys,
Been years since I built an engine so I want to make sure my memory is correct... when the marks on the timing gear align, it this TDC on the compression stroke? Need to get everything set so I know where I am when I drop in the distributor.
THANKS
Edited by TV 2M8O - 06-June-2016 at 12:52AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-June-2016 at 12:31PM
joe, you have the timing cover off looking at the gears? yes! but the TDC mark on the balancer will line up twice TDC compression stroke and again at TDC exhaust stroke
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 05-June-2016 at 2:28PM
John, yep cover is off and looking at the gears. As I was turning the crank to align the marks, it blew the paper towel plug out of the #1 spark plus hole across the shop so I figured I hadn't forgotten everything!!
Thanks buddy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-June-2016 at 2:51PM
yep align those marks, without turning it that's the spot to drop in the distributor at your #1 wire location Thumbs Up something i like to do is...  at TDC make a mark on the top edge of the aluminum part of the dist. (where the cap sits) in the center of the #1 wire tower (usually a light tap using a sharp chisel) now you have a reference to #1 at the distributor when the balancer is at TDC Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2016 at 12:56AM
I also noticed I have a small hole in the timing cover that I think may be a weep hole. It's in a dead passage next to one of the water pump passages. Not sure if it's supposed to be there (it's not a clean round hole) or just a thin spot in the casting I uncovered while blasting it! Irregular shaped and slightly smaller than a pencil eraser....
THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2016 at 3:00AM
IDK sounds like a "sand pit" Thumbs Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2016 at 4:47AM
Thanks John, that's what I was thinking too but thought I'd check before filling it in.
