  New Posts New Posts RSS Feed - 1969 Torino Data Plate Body Code Stamp
dreaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dreaser Quote  Post ReplyReply Direct Link To This Post Topic: 1969 Torino Data Plate Body Code Stamp
    Posted: 29-June-2020 at 6:01AM
New here and hope my question is in the right place.
Purchased a 1969 Ford Torino GT, driver door has been replaced.  Looking for the data plate and wondering if it could be anywhere other than driver door, or if body code is stamped somewhere like it is on the Maverick. TIA
dawn
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2020 at 1:44PM
i believe most of the 60's cars had them on the drivers door. there may be a VIN stamped on the fenderwell section like the mustang, usually there's a notch in the edge of the fender but may still be covered by the fender??? if you have the VIN marti should be able to make you a new door tag from that info??? on my mustang it was really bad and i changed doors as well so i ordered a new correct repop tag from himWink
 https://www.martiauto.com/tags.cfm
you can order a marti report too:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dreaser Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2020 at 4:39AM
Thank you! I will do that!
dawn
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2020 at 4:27PM
The 68/69's don't have the fender notch like the Mustangs, but VIN is stamped on the top of inner engine bay structure. Have to remove the fender bolts to view it. Can't recall if on both sides or just one.
