  New Posts New Posts RSS Feed - 1970 Torino GT 429 Carb Question
opschief3537 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote opschief3537 Quote  Post ReplyReply Direct Link To This Post Topic: 1970 Torino GT 429 Carb Question
    Posted: 02-March-2018 at 5:42AM
Greetings All,
I'm restoring a 1970 Torino GT 429 w/C-6 and A/C. She is an N code example and I need some expertise identifying the correct carb. From what I have determined (from a few Ford websites) she came from the factory with an Autolite 4300 series carb. I'm not exactly sure what code carb though, because I've come across two different codes; D0OF-E or a D0AF-AM. If anyone can provide some clarity, that would be excellent!
 Thanks and have a great weekend all!
Rod
Freedom is not free. Make it worth it!
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 6:51AM
The D0Of-E is a rochester quadra jet spread bore carburetor. It came installed on most 1970 429 CJ engines. It is not an autolite 4300 carburetor.
Edited by dave302 - 02-March-2018 at 7:35AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 6:54AM
In the picture below, the D0Of-E carb has a spread bore venturi pattern. Small primary venturies and larger secondary venturies.
Edited by dave302 - 02-March-2018 at 7:10AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 6:58AM
The D0AF-AM is a ford autolite-motorcraft 4300a carburetor. It came installed on some 429 n code engines in 1970. It has a square bore venturi pattern, which means that it has similar sized primary and secondary sizes.
Edited by dave302 - 02-March-2018 at 7:36AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 7:00AM
There is a picture below of a D0Af-AM square bore carb gasket.
Edited by dave302 - 02-March-2018 at 7:13AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 7:04AM
The autolite-motorcraft 4300-A carburetors came with two different primary venturi sizes. A size 1.01" venture was installed on some 1969 351W engines, and some 1970 and 1971 351C 4v engines. The 1.25" venture size carburetors were installed on the 1970 429 n code engines.
Edited by dave302 - 02-March-2018 at 9:47AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 10:20AM
There is also the motorcraft 4300D carburetors. They were originally installed on the 1972 through 1974 351C Q code CJ engines. They have a spreadbore throttle bore design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 10:23AM
There is a picture below of the motorcraft 4300D spreadbore design. It is different than the Rochester quadra jet spread bore design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 10:28AM
A seller might be advertising that they have a motorcraft 4300 carburetor for sale, but it might be a motorcraft 4300D carburetor. It can be difficult to find a way to adapt the 4300D carburetor onto a square bore intake manifold. You probably have a square bore throttle bore pattern on your N code intake manifold. There is a picture below of a square bore intake manifold throttle bore pattern.
Edited by dave302 - 02-March-2018 at 10:32AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote opschief3537 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 12:01PM
Thanks for the education Dave!
So aside from the D0OF-E, Rochester quadra jet and the Autolite-Motorcraft 4300-A, D0AF-AM, was there any other carburetors used on the 1970 Torino GT, N code 429, Automatic with A/C that I can continue to search for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 1:12PM
Some early 429s were available with a 2bbl...
2005 F-150 STX 4.6, 3.55 LSD
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 1:38PM
The D0OF-E Rochester quadra jet carbs were used on the 1970 C Code 429 cobra jet engines and they were probably also used on the 1970 J Code 429 cobra jet torinos with the ram air option. I have never heard of the ford factory installing them on the 1970 N code 429 engines. There might be an adapter plate that you can use to install the D0OF-E onto your engine. But the Autolite-Motorcraft 4300-A, D0AF-AM would be more of a direct fit onto your intake manifold if you have the 4 barrel square bore pattern on your intake.
Edited by dave302 - 02-March-2018 at 2:01PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2018 at 2:36PM
opschiefe3537 what intake manifold do you have, if i missed it ?
the Ford Rochester Quadrajet is very rare 1 year only IIRC, the 4300-D is a spreadbore but came later model years, yes there were 2bbls even if Chilton/others don't list the option
if you have a Holley 4150 pattern square bore intake, measure the throttle bores because some Holleys have larger diameter throttle blades and they won't open all the way
http://www.championcarburetor.com/7074-motorcraft-4300a-carburetor-600-cfm-4v-remanufactured-p-10694.html
probably pretty much the same carb you'd get from Rockauto
Post Options Post Options   Thanks (0) Thanks(0)   Quote opschief3537 Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2018 at 1:46AM
Thanks for all the help guys!
The build sheet and Marti report show that she was an N code ordered with a 429 4V. She was bucked May 7, 1970 and actually built May 12, 1970.
I'm gonna search for an original 4300-A, D0AF-AM carb.
Question, as I search for a date code correct carb for my Torino, would a Feb to Mar dated carb be correct? I thought I read that engine parts should be dated 60-90 days before the actual build date of the car?
 Have a great weekend.
Rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2018 at 3:07PM
I checked the Ford Master Parts catalog.  It lists a bunch of carbs for the 429 Torino's (N-code).
C6 Trans and Imco - D0AF-K, AG, AM, AN
I know my car was build the end of march, most of my engine parts are dated sometime in February.
Post Options Post Options   Thanks (0) Thanks(0)   Quote opschief3537 Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2018 at 1:53AM
Thanks Vince!
Are all of those carb codes correct for an N code, C-6 with A/C?
Rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2018 at 6:46AM
Originally posted by opschief3537 opschief3537 wrote:
Thanks Vince!
Rod
According to the parts catalog, those are all correct.
There is only two listings in the catalog for the 429 N-code engine. One is for the automatic (as I listed) one is of the 4-speed.  It does not specify with or without A/C in either listing.  The CJ cars used different carbs depending if A/C or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2018 at 9:52AM
rear gear ratio may play into the A/C or not thing, and thus the carb thing
a car spec'd with a performance rear gear may've got a larger venturi carb
Edited by Rockatansky - 06-March-2018 at 9:54AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-March-2018 at 2:03PM
This page was generated in 0.092 seconds.
