  New Posts New Posts RSS Feed - 1970 wiring issue?? HELP
carguy47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carguy47 Quote  Post ReplyReply Direct Link To This Post Topic: 1970 wiring issue?? HELP
    Posted: 09-March-2016 at 4:00PM
Hey guys. I just had an issue pop up without warning or prompting on my part.
I was driving home and the car started to sputter and finally die. I went to check the battery and I have NO power. I tried jumping the car and switched the battery. ZERO power anywhere!
Two days later I had some time to work on it and it fired right up immediately? The issue seemed to resolve itself. However it ran for 5 secs - died AGAIN! ZERO power anywhere.
Switched batteries and the headlights and interior light came on. I went to start the car and the battery sparked and ZERO lights again!
I charged the battery again, no issues with battery. Four days later I put the battery back in and I had interior lights. I went to check the headlights and BAM... ZERO power again???
What the heck is going on?  Any ideas?  DeadDead
Ranchero Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 09-March-2016 at 5:22PM
Battery cable or cable clamp(if you have replacement cable ends)? I had a replacement cable end, on one of my cables, & after a short time decided to act up one damp night in the middle of nowhere.
jversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jversch Quote  Post ReplyReply Direct Link To This Post Posted: 10-March-2016 at 5:43AM
Check all your power and grounds . Sounds like you have voltage drop when you put a load on the system . Even if it looks clean , cleaning them may fix it .
Jerry VerSchneider
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-March-2016 at 10:47AM
I had the end rust off my starter cable right at the starter. Rest of car got power, until I cranked starter and the cable end arced and killed the battery. Couple hours later, I could repeat the process...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 10-March-2016 at 11:53AM
  X2 Been there too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-March-2016 at 2:21PM
yes sounds like the battery cable either pos or neg, battery end or the other end somewhere
Post Options Post Options   Thanks (0) Thanks(0)   Quote carguy47 Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2016 at 2:02PM
Spot on guys. I replaced and Cleaned ALL ground straps and bingo...car runs again. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2016 at 2:22PM
Clap
