  New Posts New Posts RSS Feed - 1972 1978 frame.?
1972 1978 frame.?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: 1972 1978 frame.?
    Posted: 24-November-2019 at 2:53AM
Hi Forum..qq...are the Torino frames from 1972 and 1978 the same?
As you may all know, I need a frame piece for my 1972 GTS..just where the rear lower control arm is......are these frames the same?
Thanks...
(Johnny......any cutting this weekend?..I am desperate for news..)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2019 at 5:25AM
i had too many errands to do yesterday Confused but if the weather is good today i may attempt it? if it wasn't still a whole car it would be easy...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2019 at 6:00AM
ok Johnny...lemme know...Brake out the plasma cutter!Tongue
Are the 72 and 78 frames the same? I saw a 78 frame and it did not look quite like mine in the problem area around where the rear lower control arm mounts......
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2019 at 8:17AM
not completely sure on the 77-79's??
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2019 at 8:45AM
i'm gonna work on getting that piece out...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2019 at 11:30AM
got it out!!! what a painConfused  i'll email you a pic soon....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2019 at 3:38PM
Johnny...friggin AMAZING help! Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2019 at 5:59PM
WinkThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2019 at 1:19PM
Yes, the '72 and '78 frames are the same in the area your are rusted.  The frame basically was the same from '72 to '79.  However, in front of the front axle and behind the rear axle was altered depending on the year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2019 at 2:10PM
so you could swap the front & rear bumper mount extensions (frame horns) from the 72 frame to any other same wheelbase frame and it will work. wheelbase can be adjusted by sectioning the middle, paying attention to body mount locations. do you have a line on a donor frame local?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2019 at 2:21PM
 Wink already on it, cut ready to send...Big smile
