  New Posts New Posts RSS Feed - 1972 - 1979 Body Insulator Bushings UPDATE..UPDATE
 Post Reply Post Reply Page  123 10>
73GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Topic: 1972 - 1979 Body Insulator Bushings UPDATE..UPDATE
    Posted: 20-September-2010 at 1:42PM
Big smileI HAVE FINALLY COME UP WITH THE PERFECT MOUNT.
Follow this topic and then read my conclusion!
CONCLUSION:
OK, here it is.........................
Buy 10 body mounts for a 2003 - 2009 Ford Crown Victoria with a 2006 part number.
THE PART NO's. ARE (UPPER MOUNT)6W1Z-5400396-A AND (LOWER) 6W1Z-5C155-AA. YOU CAN ORDER THESE PARTS WHOLESALE THRU BOB UTTER FORD OUT OF TEXAS.
Take the center "tube" (shiny one) and cut it down with a tube cutter to 1 1/4". The ugly one is the old one for comparison.
Here is a pic of it cut.
Don't forget to dress on the grinder.
This is why you have to cut the tube...........
The new one on the left is too fat between the body and frame. This will change after you cut the tube.
This is it in the frame and at stock height.
The best part as you can see is I am able to reuse the original bolts. Just clean up and coat with Loctite.
Next..........I will find a solution to the 2 core support mounts.
Stay tuned WinkBig smile
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2010 at 1:47PM
Good deal. Thanks for the knowledge.
91 F-150
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2010 at 2:20PM
Genius! I look forward to seeing the rad support mounts.
What is the cost on these, roughly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2010 at 4:05PM
$10.68 top (6W1Z-5400396-A) & $9.44 bottom ( 6W1Z-5C155-AA) x 10 mounts = $201.20 Westway Ford Parts Department.
I know Bob Utter Ford has them, but they're cheapest at Westway Ford Parts Department Wink
Edited by 73GTS - 20-September-2010 at 4:11PM
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2010 at 5:11PM
Nicely done there Jim.
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2010 at 2:13AM
do you need to trim down the rubber part of the mount as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2010 at 2:22PM
Nope. When you tighten it down, it squooshes to a perfect fit.Wink
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2010 at 3:10AM
Are these installed in your car now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2010 at 11:29AM
Body won't be back on the frame until atleast next summer.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2010 at 11:57AM
....... I really don't want to have to be the first one to do before and after pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2010 at 1:06PM
This is the mount on the frame and it is completely tight as if bolted
to the body. You will notice the big washer that I used under the nut
in place of the body. It is the exact size as original. I guess this is the
before shot. I can't do the after shot 'til later down the road.Approve
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2010 at 1:17PM
We need rad support bushings, as well.. I spoke with Andy, he said what he used collapsed over the years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2010 at 1:40PM
I'm working on that. Will post when I find something acceptable.Wink
Jim
Ron Earp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2010 at 4:32AM
Thanks much for posting this info. My body is due back next week and we'll be putting these to use!
04 Ford Lightning
72 GTS BB Stroker & Toploader
98 Mustang ITS SCCA #38
08 Buell Ulysses
GT40s.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2010 at 5:28AM
Dumb question here...
Can you do a side by side pic of the new and old one MOUNTED like the pic of the new one you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2010 at 5:31AM
Maybe. Have to wait for the new ones to arrive.  And, bear in mind my old ones were original and I don't recall any of them coming out of the car that seemed to not be deformed all the hell.
04 Ford Lightning
08 Buell Ulysses
GT40s.com
iangj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iangj Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2010 at 8:06AM
I have a few good original ones so when the Crown Vic ones arrive I can take a side-by-side for you.
Ian Glyn-Jones
Fonthill, Ontario, Canada
'72 Montego GT Q Code
Montego GT Registry
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2010 at 2:34PM
This thread should be a sticky also and put under the first thread.......
1972 - 1979 Body Insulator BushingsWink
PLEASESmile
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2010 at 6:27PM
Without reading 4 pages.. Why do we have TWO threads about body insulator bushings? Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2010 at 2:24AM
Someone started a new thread instead of adding on to the original one.
From what I have seen on THIS thread... seems to be the perfect new body mount option that is readily available.
