1972 Front Clip Disassembly |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 4179 |
![]() ![]() ![]() ![]() ![]() Posted: 26-March-2018 at 4:31AM |
I am going to start the disassembly of my '72s front clip soon. Can someone give me some idea what the best order of disassembly is? I know the '72s are much more complex than the '73 and newer cars. Any tips, order of disassembly would be a appreciated. I know there are lots of people who have done it here before, and I am not body many by any stretch. |
I found a thread about clip reassembly. It says the order is:
1. Core support 2. Fender wells 3. Put on the fenders 4. Headlight assembly 5. Grill 6. Header panel 7 hood 8 valance 9 bumper So if I reverse it I guess I should be okay: 1. Bumper 2. Valance 3. Hood (already removed) 4. header panel 5. Grille 6. Headlight assembly 7. Fenders 8. Fenderwells 9. Core support According to these instruction, the outer fenders and inner are removed separately? Is this the best method? My plan is to remove all the sheetmetal on the front end, and have the fenderwells, the cores support, batter tray, other braces, etc, all blasted and powder coated. I will also strip all the undercoat off my frame and repaint it, while I want to repaint my firewall. I figure with the engine and trans out, now is the time to detail the engine compartment. If anyone can offer any advice on this job please chime in. I am hoping I can get it all back together and aligned decently when it comes time. |
n2fordwagons ![]() Senior Member ![]() ![]() Joined: 20-July-2013 Location: GA Status: Offline Points: 2159 |
Not exactly the same, but when taking my '79 Tbird apart, that was the approximate order. The fenders and inner fenders would be the same. It would be easier to take the fenders off to get to the inner fenders, although I don't think it's impossible to remove the inner fenders without removing the fenders, from what I've heard.
Hood Bumper / Grille Head panel / Headlights Fenders How it looks now. ![]() Edited by n2fordwagons - 28-March-2018 at 4:52AM |
Jeff
76 Mercury Montego MX Villager w/ 460 (SOLD) 79 Ford Thunderbird w/ T-tops 69 Ford Country Squire |
Thanks Jeff, this is helpful. So you removed the outer fenders and left the inner's in place? I wasn't sure if it was better to remove both the inner and outer as one piece or do it separately?
From doing some searches here, it seems some say the best way is to remove the lower valance, then the front bumper and brackets as one unit. I found the diagrams for the '72 front end and MAN are there a lot of parts. |
russosborne ![]() Senior Member ![]() Joined: 01-January-2015 Location: Glendale AZ Status: Offline Points: 664 |
I thought I'd be smart and pull up the shop manual from Ford. Not a big help.
Then I thought about the Jim Osborn assembly manuals, but it looks like he doesn't do any for the Torino/Ranchero. So if anyone has a detailed order of disassembly it would be appreciated. Or is there an assembly manual out there for these cars somewhere? Thanks, Russ |
7T9_Tbird ![]() Senior Member ![]() ![]() Joined: 04-December-2017 Location: Athens, Alabama Status: Online Points: 482 |
Found this on the ol' interweb..
![]() https://www.themotorbookstore.com/1972-ford-cars-factory-shop-manual.html?cmp=googleproducts&kw=1972-ford-cars-factory-shop-manual&gclid=EAIaIQobChMIjoP78rWR2gIV1LfACh3MTQCAEAQYASABEgJHFfD_BwE
John
Russ, I do have some detailed parts catalog diagrams that show how all the parts go together. It's on a locked PDF so I can't screen shot it to post here. When I have a chance to print it off and scan it I will add it to this thread.
John, thanks for the info. I already have the service manuals, unfortunately it doesn't really get into disassembly detail. I just know people in the past here have gone on about how complicated the '72 front end is, so I just want to be prepared and do it right.
Edited by 72FordGTS - 29-March-2018 at 12:22PM |
Thanks.
I have the factory service manuals also, and while they are ok for taking off one thing, they aren't great for taking the whole front sheet metal off. Russ |
I got around to scanning the front end diagrams. As you can see, it's not a simple front end. I am hoping to have to have some time to tinker with it this long weekend. ![]() ![]() ![]() |
Thanks!
That will be a big help. Hopefully my brain will be able to sort out what the correct order is. Russ |
So I have had sometime to work on the car this weekend. It wasn't as bad as I though it'd be. My order of disassembly is as follows:
This will completely remove all the front end sheetmetal. It looks like now I only have to remove the outer fenders, the inner fender and then the rad support (which I will do once I find some space to store that stuff). |
T-Bird_79 ![]() Member ![]() Joined: 05-May-2017 Location: Riga, Latvia Status: Offline Points: 103 |
Good, that it turned out so well!!!
I am too planning to start disassembly of the front clip on my car. Goals are the same as Yours-replace the engine, check/repair the transmission, paint front part of the frame, repair and paint inner fenders and core support, the only thing, that's different is the condition of Your car. ![]() Will follow the progress with Your car! |
Andris
1979 Ford Thunderbird 1977 Opel Commodore Coupe Euro personal luxury car 1969 Vauxhall Viva small American 1989 Opel Kadett GSi 16V known as Pontiac LeMans 1978 Moskvitch 412 Soviet rally |
Thanks John. When I get a chance, I will post some pics in my project thread.
72torino... ![]() Member ![]() Joined: 12-June-2017 Location: Ohio Status: Offline Points: 90 |
Vince,
Sorry to dig up an old thread. But those assembly diagrams you posted. Is there a book for sale somewhere that has that information for the complete car? Thanks, Adam
The diagrams are from the Ford Master Parts Catalog. You can buy digital versions for a reasonable price at many vendors.
Tweet
