1972 Gran Torino Trunk Weather Stripping Metal |
Richo
Brand New Member Joined: 24-March-2015 Location: Rock Hill, SC Status: Offline Points: 1 |
Posted: 24-March-2015 at 4:56AM |
Do any of the Gran Torino parts companies sell the metal that goes beneath the trunk weather stripping? This area is pretty porous with rust damage. Thank you!
fordismyboss
Senior Member Joined: 05-January-2014 Location: SF Bay Area Status: Offline Points: 397 |
My 72 GTS has the same issue. Any info out thee to share?
I'm currently looking for a donor car for the upper drip channel of the trunk. Anyone ever repair this area by fabricating a new channel? |
Montego01
Senior Member Joined: 16-December-2012 Location: Largo Status: Offline Points: 565 |
If you don't have a donor car, the only way I can think of is to us the flexible edge patch panels.
I used this on my flares and it worked great. You'll have to weld these in, then duraglass (or equivalent) them to sculpt if the way you want it, then coat it with bondo. They come in 3/4" and 3" I believe. You can Google
Patch Repair Metal Panels flexible edge |
NorthElite
Member Joined: 22-February-2015 Location: Finland Status: Offline Points: 195 |
I need to make it too and I don't know yet how I going to fix it. Maybe I use small metal curving machine to make my lower and left side drip channel of the trunk. My upper channel and right side is OK.
Some part of the channel is made of two pieces and spot welded together. Lower corners are difficult to do and maybe I go with two pieces in corners too. |
Eliteman76
Pictures are helpful.
In my case I bought a parts car just to get the steel I needed.
Pondering: #99Problems |
