  New Posts New Posts RSS Feed - 1972 GTS custom wagon
NwOh_Starsky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 3:55AM
Closer to the panamera. I was thinking graft the fastback rear to the sedan roof, keeping all that is there on the sedan.
Adam
1975 Gran Torino sedan
2014 Dodge Durango
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 4:11AM
NW, I have a gts roof sitting in Kansas if you need one.
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 4:21AM
That'll have to be my second one....
Adam
2014 Dodge Durango
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 4:46AM
Actually, that sounds very cool. I'll bet the reception would be awesome, given the fact 4 door fastbacks are all the rage now.
Why not go the Full-Monty and graft a hatch back there (like the Panamera)? Utilize the lower portion of the decklid, a larger back glass, reinforcements on the rear of the roof for the hinges, and modify as needed.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 4:47AM
Gran Torino Runabout?
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 5:53AM
Funny you say that. Ford did a Montego concept where they did a full hatch and a tailgate and fit a 6 wheeler in the back of a two door Montego.
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 6:09AM
Joe you nailed it. That's exactly what I wanted to do. I thought it would be sweet. Very wagon like very cool.
Adam
2014 Dodge Durango
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 6:26AM
If a person was so inclined...
Grab the hatch off a Nova hatchback (if you want the original lines of the 4 door kept) and widen to fit. Novas kept that "bend", mimicking a formal roof style. Then modify with the Torino trunk lid. Use the Nova recess channels, since it sits flush with the upper body lines (no side seam showing) and proceed.
Grab the hatch off a Hornet Sportabout (if you desire the Torino Sportroof lines) and widen to fit. Again, use the inner channels off the Sportabout so that it sits flush with the upper surfaces and does not show a seam from the sides. Again, use the Torino trunk lid.
This is doable with the right skills, I think.
1972 GTSquire Wagon
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 9:16AM
...and the right blade in the sawzall? lol
JT, USAF Ret.
1971 Ford F100 "Lizzy"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 9:23AM
Sawzall for cutting off the roof section but cutoff wheel for trimming and fitment
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 9:38AM
1970 Montego Sporthauler:
JT, USAF Ret.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 9:39AM
Have you guys seen this photoshop beauty?
JT, USAF Ret.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 2:11PM
Adam I have Andy's roof skin BUT I also have a full 72 Sport at the farm...the car is JUNK but the roof stuff you need is in decent shape
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 2:36PM
I like the basic concept of "guest's" car, but would probably section a wagon onto a formal to keep the shorter wheelbase, and I think the formal rear side window would look cleaner.
That Montego sporthauler reminds me of Dan the Ranchero Man's rear tonneau/hatch thingey...Thumbs Up
just on an earlier year.
The thing I wonder if "guest" considered:
4 door/wagon uses a different windshield than a 2 door/ranchero. A-pillar post angle is different.
This will affect the side windows in a door swap.
When you do this swap on a fairmont, there is a 2 door sedan (non-futura) that matches post angle and windshield.
Edited by Big Bird - 10-July-2014 at 2:44PM
2005 F-150 STX 4.6, 3.55 LSD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 3:10PM
All the 72-79 cars use the same windshields and A-Pillars
occupant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote occupant Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 3:27PM
I like the lines of that 71-73 Cougar. Makes me want to go looking for late 60s Rivieras....
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2014 at 6:38PM
that is slick! it does look like a riviera, i like it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2014 at 2:39AM
Look you all help fund a 25x30 garage build and I'll chop whatever you want
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2014 at 1:14PM
And I'll help build the garage and start chopping with you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2014 at 2:41PM
Regul8r wrote:
"All the 72-79 cars use the same windshields and A-Pillars"
I must have G.M. A bodies on the brain again...Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2014 at 2:44PM
*snicker*
1994 Mark VIII
Retired 60s NHRA Anglia
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2014 at 3:18PM
*snicker*
Why you whippersnapper! As soon as I find my Geritol, I'll show ya! LOL
