  New Posts New Posts RSS Feed - 1972 Montego With Wood Brothers Paint Scheme
mtburger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtburger Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 7:31AM
Thanks Guys, the comments are much appreciated.
I only put a about 2-300 miles on the car from January to October when I put it away.
Is seamed like every time I got one issues resolved, a couple more would pop up.
Also, I went WAAAAAY out of my way to go to the smaller C4, and that had a few unexpected issues, the biggest one, was the reason I went to the Hughes torque convertor.
My reasoning for using the small 157 tooth flex plate and bell, instead of the 164 tooth stuff was that it would take a good bit of weight off the crank to help with performance and also for extra header clearance.
When I stored the C4 from the Monarch, I wanted to avoid a mess in the basement, so I drained the transmission and tossed the convertor. I figured if I needed one, I would just get a re-man Dayco for $40.00 or whatever like I have about a dozen times in the past, nope not even close.
I could not find a rebuilder / supplier that had a 157 tooth C4 stock replacement torque convertor left on the east coast, and buy the time I got one located, shipped, and payed the core charge, it was cheaper to get a performance one through Summit, so I ordered the Hughes.
The difference in weight between the stock 164 tooth unit and the 9 inch Hughes was about 10 pounds, plus the additional stall made it an easy decision.
I forgot to mention several other updates that were done over the same time frame, like gas tank & sender, Petronix ignition & coil, the rest of the exhaust to go with the headers, and I replaced the pumpkin with a 4.10 unit that was previously in the Montego GT.
By the time I put the car away, it was pretty quick, especially for only having a 2 barrel carb on it, but certainly not as fast as it looks.
I have some other 351C parts like a mild hydraulic cam & lifter kit, and a nice used Edelbrock Performer RPM Air Gap intake that would give it a good bump, but it runs excellent right now, and I think I would like to enjoy it for a while as is before I swap to the 460 / stick combo, although I may take it to New England Dragway as is to get a baseline.
The car show pictures were form the Spindles Car Club Labor Day Weekend show in Pembroke, MA and a it drew a ton of attention.
The last couple things I did were to fix some appearance issues.
The previous owner used 3m Blue masking tape for the stripes, nice.
Every time I washed the car, some of them would wash off, so I had that straightened out.
I also had the Mercury script decals made up for the lower rear quarter panels, then bought a couple of the "Competition Proven" Holman & Moody decals and put those on too.
Mike H.
Edited by mtburger - 18-May-2017 at 7:32AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 8:50AM
at least use 3M Blue electrical tape LOL
i was wondering if you've seen the HM cam data plate? i can't find them separate but there's on in this bag o stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtburger Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 9:48AM
No I have not.
I would try giving the people running the website a call, they may be able to get you what you are looking for. That is where I got the stickers, and a couple T shirts.
More than likely I am guessing, those are gone, so you might have to pony up the $60.00 to that joker if that is an item you are hot for.
http://www.holmanmoody.com/
Mike H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 2:03PM
Looks really good, great work.  You should post your spring choice, a picture of the stance of your car in the coil spring thread.  Will be useful for someone looking for a spring in between a stock and the CVPI springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 1:17AM
What a great build, and the pics of each step (especially that front suspension) is great information!
Matt
1972 Montego MX
1973 Gran Torino Sportsroof
2003 Mercury Marauder 300A
2003 F-150 5.4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 4:42AM
i was thinking for you, it'd be a nice HM touch to your engine bay Thumbs Up
