  New Posts New Posts RSS Feed - 1973 429 exhaust manifold questions
MeyerDerSack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MeyerDerSack Quote  Post ReplyReply Direct Link To This Post Topic: 1973 429 exhaust manifold questions
    Posted: 16-March-2015 at 7:43PM
Hey Guys, greetings from a newbie Wink
i noticed that my exhaust manifold are leaking. Now i want remove the manifold.
Is it possible to remove the exhaust manifold WITHOUT pulling the engine?
Where can i get the correct screws?
Have a nice day.
Daniel
1973 Gran Torino Sport sportsroof 429/C6 Greetings from Germany. Sorry for my bad english.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2015 at 2:37AM
I'll start this off with what I know:
To remove factory exhaust manifolds, you will not need to remove the engine.
I do not know the bolt size. I have headers, so they will be a much shorter bolt. There are people here who do run exhaust manifolds and may have that size.
Summit racing (and many other companies) will stock the correct bolts, and will ship international.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MeyerDerSack Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2015 at 4:37AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2015 at 4:56AM
DO NOT USE STAINLESS!!!
Stainless steel is VERY brittle! I stay away from stainless whenever I can.
Stainless also does not like to "play nice" with other metals. issues getting them out later.
I would use grade 5 or 8 bolts with a washer.
here is a full set...
MIGHT buy 2 or 3 sets so you didn't have to use those double sided studs, but for $11 that is unbeatable.
You will spend more than that buying grade 8 and washers at the hardware store.
Besides IF they don't work... ebay return them!
Found the same set on Rock Auto for $9.69 and they ship to Germany, NO PROBLEM.
IF you don't need all those stud ones, just cut the stud off and use as a bolt.
Hopefully they are the same length as your manifolds are different.
Edited by Regul8r - 18-March-2015 at 5:29AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2015 at 10:44AM
+1 on NOT putting stainless into Iron heads. Engine heat cycles will seize them up (especially in dissimilar metals) and they will not come out without ruining the threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2015 at 1:21PM
YUP, Stainless does not "PLAY WELL" with other metals!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MeyerDerSack Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2015 at 7:50PM
Thx for your help. I ordered 3 sets from Rockauto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MeyerDerSack Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2015 at 3:48AM
I also bought this:
What are the correct manifold for the H-Pipe? First or secound pic?
thx Daniel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2015 at 2:21PM
The first one is the one used on the torino's.
carguy47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carguy47 Quote  Post ReplyReply Direct Link To This Post Posted: 08-November-2015 at 3:30PM
The stock BBF manifolds work just fine. I have them on my car.
