  New Posts New Posts RSS Feed - 1973 Gran Torino Restomod
 Post Reply Post Reply Page  <1 293031
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 1:20AM
It had always been the plan Wink I want a sports car eating monster.....easiest way? Turbos!
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 7:54AM
Wish I had a slack belt sander....would make life so much easier than trying to form a bracket with a grinder alone.
But this is the way to make a Chevy nascar pas pump fit a Ford big block! 99p well spent anyway......love an ebay bargain
Barnaby
gentrysgarage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 8:23AM
So Exciting and clean looking Mods! I can't wait for more!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 8:32AM
Thanks! This is being done to give me a load more clearance for the turbos......alternator is low mount on the other side so putting this as a low mount on drivers to replace the massive original one!
Should hopefully get my heads back tomorrow so if I do I'll be attempting to slam the engine back together over the weekend and fire it up!
However after that you may be waiting a while for more updates, I've accepted a job 5 hours from where the car is!
Means money for more parts but progress will be a bit slower, this adulting thing is hard Tongue
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2017 at 8:04AM
So I spotted this on ebay and being a 20 minute drive from me pounced........£120 so not too bad, its a 15.5" and its just the right fit. Snug but not uncomfortable once padded out, I could get away with a hoody or possibly a jacket too but the main thing is the hips are spot on!
Anyway.....because race car.
Will definitely have to raise up the seat a bit though! I cant see anything over the wheel....this is with the camera held at eye level to kind of show what I can see when sat in there
And finally just a mini thing but with the heads due back from the machine shop tomorrow (was meant to be today, but a guide snapped during machining so a new one is being put in) I gapped the plugs, 57thou worth.....could push it to 65 but gonna see how it performs first!
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2017 at 3:52PM
forced induction doesn't like extended plug gaps, less is more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2017 at 11:03PM
Yes.....but to run the engine NA immeed the gap. Turbos will not be fitted for a while and I want to test run the engine later
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2017 at 10:21AM
Big update! Picked up the heads this afternoon
Spent at least an hour cleaning up all the packing grease on the block and bores, cleaning out stud holes and then installing the heads.......f**k I forgot how heavy they were when you're leaning over a fender!
Installed the rockers (wrong) I realised when I was trying to start it, so tomorrows job is to reset the lash......but its together, fuel plumbed, wires hooked up (ish) and ready to start! It did cough and splutter earlier but yeah.....f**ked up the lash by rushing it
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2017 at 11:52AM
nice! Big smile
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2017 at 1:53PM
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2017 at 8:34AM
Unfortunately the starter motor is very much dead :(
Barnaby
