  New Posts New Posts RSS Feed - 1973 Gran Torino Restomod
 Post Reply Post Reply Page  <1 293031
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 1:20AM
It had always been the plan Wink I want a sports car eating monster.....easiest way? Turbos!
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 7:54AM
Wish I had a slack belt sander....would make life so much easier than trying to form a bracket with a grinder alone.
But this is the way to make a Chevy nascar pas pump fit a Ford big block! 99p well spent anyway......love an ebay bargain
Barnaby
gentrysgarage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 8:23AM
So Exciting and clean looking Mods! I can't wait for more!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2017 at 8:32AM
Thanks! This is being done to give me a load more clearance for the turbos......alternator is low mount on the other side so putting this as a low mount on drivers to replace the massive original one!
Should hopefully get my heads back tomorrow so if I do I'll be attempting to slam the engine back together over the weekend and fire it up!
However after that you may be waiting a while for more updates, I've accepted a job 5 hours from where the car is!
Means money for more parts but progress will be a bit slower, this adulting thing is hard Tongue
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2017 at 8:04AM
So I spotted this on ebay and being a 20 minute drive from me pounced........£120 so not too bad, its a 15.5" and its just the right fit. Snug but not uncomfortable once padded out, I could get away with a hoody or possibly a jacket too but the main thing is the hips are spot on!
Anyway.....because race car.
Will definitely have to raise up the seat a bit though! I cant see anything over the wheel....this is with the camera held at eye level to kind of show what I can see when sat in there
And finally just a mini thing but with the heads due back from the machine shop tomorrow (was meant to be today, but a guide snapped during machining so a new one is being put in) I gapped the plugs, 57thou worth.....could push it to 65 but gonna see how it performs first!
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2017 at 3:52PM
forced induction doesn't like extended plug gaps, less is more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2017 at 11:03PM
Yes.....but to run the engine NA immeed the gap. Turbos will not be fitted for a while and I want to test run the engine later
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2017 at 10:21AM
Big update! Picked up the heads this afternoon
Spent at least an hour cleaning up all the packing grease on the block and bores, cleaning out stud holes and then installing the heads.......f**k I forgot how heavy they were when you're leaning over a fender!
Installed the rockers (wrong) I realised when I was trying to start it, so tomorrows job is to reset the lash......but its together, fuel plumbed, wires hooked up (ish) and ready to start! It did cough and splutter earlier but yeah.....f**ked up the lash by rushing it
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2017 at 11:52AM
nice! Big smile
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2017 at 1:53PM
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2017 at 8:34AM
Unfortunately the starter motor is very much dead :(
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2017 at 10:48AM
Well I've taken a week off work for my birthday so today I started making the turbo headers, well actually yesterday.....marking up and clocking the pipework to where I wanted, box of 90's and 45's. Just need to get the first few bits of pipework sorted so it clears everything then I can make it up and get it to the collector
Nice simple bit of drilled and tapped box section to use to stiffen up the flange and keep everything in place when welding
Also had to make a little die in order to form the pipe to shape. This took me f**king ages, hogging it out with a 4.5" grinder was a nightmare......but it worked
From round to oval-ish
Mocked up the pieces to check for bolt clearance, looks like I'll have to squeeze them a little more as a few are pretty tight, but it should all come together easily enough now. Crushing 2" Sch10 pipe is a nightmare
Barnaby
cggrob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cggrob Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2017 at 10:56AM
I have to say....I admire your determination!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2017 at 3:04PM
Nice to see you posting on here again.  Looking forward to following the progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2017 at 10:35PM
Thanks guys, unfortunately this will probably be the last you see of it for a while! I'm back to work next week so wont have time to do much to the car.
Still got a huge list of things to do before I can even contemplate driving it though, off the top of my head;
Fit brake lines
Fit pedal box
Fit speedo
Fit new starter
Modify floor pan for Kirkey seats
Repair rear screen frame
Lift engine and trans 1" for extra header clearance
Complete headers
Fit turbo oil lines
Mount engine oil cooler
Make intercooler pipework and intercooler brackets
Make PAS pump bracket
Fit new UCAs
Build new front brake system
Pull trans and fit new TC plus SFI flex plate
Finish front bumper
Modify hood for turbo clearance
Build exhaust system/hater pipe
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 19-September-2017 at 10:19AM
Add fit block plate and notch chassis rails to the list
Here you can see that I cant get the headers in on the drivers side due to the chassis rail, fit fine and clear stuff when you put each pipe in one by one. But tacked up to the flange its a no.
The passenger side is a little better with pot 2 being the only interference issue, but I may as well notch it symmetrically
So the plan will be, heavily notch the chassis, fit block plate, drop engine .5" for more clearance and pray it fits. Probably would have been ok if I went for the 1.5" bore instead of 2" but I want all the power
Here you can see the interference point on the passenger
And these are the proposed cut areas
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2017 at 11:46AM
For those who know the code
HEH-BT Toploader
Or in non anorak close ratio Toploader from 1965, 28 spline.
This will be built up at some point to include the big input and output but for now it'll be fine!
Barnaby
This page was generated in 0.098 seconds.
