  New Posts New Posts RSS Feed - 1973 Gran Torino Spindle to Lower Ball Joint
grandpops4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Topic: 1973 Gran Torino Spindle to Lower Ball Joint
    Posted: 12-March-2019 at 11:00AM
When I try to tighten the spindle to the lower ball joint on the lower control arm the ball joint spins with the nut. Is there any way to stop this.
Thanks
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2019 at 11:11AM
put a jack under the control arm and lift.
Some guys will squeeze the ball joint together with the spindle with a big pair of channelocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2019 at 1:46PM
+1, either should work.  Just checking, but did you inspect the ball joint to make sure it still good before you button it up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2019 at 2:44PM
with the jack near the end of the arm, raise the whole assembly about an inch so the spindle is free if that don't work smack the spindle down ward with a big hammer to get the taper to grip Wink
