  New Posts New Posts RSS Feed - 1973 Ranchero toploader in a Torino?
threedwizard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote threedwizard Quote  Post ReplyReply Direct Link To This Post Topic: 1973 Ranchero toploader in a Torino?
    Posted: 21-October-2017 at 6:06AM
I'm trying to return a 1970 M code Torino GT back to the factory 4 speed, it has been changed to an automatic. I've located an entire 1973 351C\toploader Ranchero car with all the parts and z bar setup I could purchase. Will this work? I think I will need to change the driveline yoke to 31 spline and get a Torino crossmember, steering column, and pedal set. I don't know much about the 72-76 era, but would think the z bar setup should be the same.
Thanks for any input on this before I commit to buying the donor car.
Confused
1971 Torino GT Convertible
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 6:14AM
Yes. Ranchero of this era is based on Torino.
72sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 6:27AM
72 up Z-bar I don't think will work in a 70
Tom
1972 Gran Torino Sport 4Spd
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 6:43AM
the parts brake down is 1970 & 1971 only.the pedals and z bar.for 1972 and up is the same way.the pedals and z bar only 1972 and up. the trans should work the correct shifter to the year of car.the 1970 crossmember is the same for auto/stck/351 and 429....
Edited by torinojon - 21-October-2017 at 6:44AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote threedwizard Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 6:49AM
I was afraid the z-bar setup would be different. I knew about the pedal set. I could still use the bellhousing back maybe? I would think the clutch fork& shifter could work too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 6:52AM
the clutch fork is the same way 1970 & 1971 only and the 1972 and up only.bell housing and fly wheel will work in any year....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 7:04AM
Yes 1970 was unibody / 72 + went to a frame some parts may be different
unless originality is important maybe consider an internal rail trans & hydraulic bearing ?
the RUG trans tail housing & shifter mount are likely different also as the 72-73 is a unique oddball
don't forget the extra long speedo cable
Edited by Rockatansky - 21-October-2017 at 7:15AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 2:05PM
its easy to do the factory set up.i made my upper rod and lower rod.thay want to much for factory  replacement rods.that will wear out if every thing is not straight.the 1970 set up uses all small block parts for the z bar.the felt and the pivot ball on both side of the z bar are from a 302/small block.every place has it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 3:06PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2017 at 6:04AM
Gutting an original 1973 Ranchero 351CJ/4 speed car would be an absolute shame. Less than 1000 made. I'd buy a separate transmission and separate hardware if possible.
1994 Mark VIII
Retired 60s NHRA Anglia
Post Options Post Options   Thanks (0) Thanks(0)   Quote threedwizard Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2017 at 8:08AM
If someone has a reasonable priced RUG Toploader, bellhousing, flywheel, shifter, and clutch fork for a 70/71 I'm game.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2017 at 9:13AM
Yeah, I missed the year on the Torino...
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2017 at 9:56AM
Better off retrofitting a hydraulic setup for the clutch anyway.......unless you must have originality for concourse reasons
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2017 at 10:01AM
My son and I are looking for a project.  We wanted a 72 Torino/ Montego GT, but we'd be hard pressed to pass up a 4 speed car if it was complete.  I have the Top loader(RUG -BG1) from a 72 Torino complete with bell, fork,resurfaced flywheel, and 72 Torino shifter( I'm not sure if that will fit 70-71)
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote threedwizard Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2017 at 5:02PM
Where are you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2017 at 9:57PM
Poynette.  It is about 30 north of Madison WI
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote threedwizard Quote  Post ReplyReply Direct Link To This Post Posted: 24-October-2017 at 3:00AM
PM me your contact info please
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 24-October-2017 at 12:30PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote threedwizard Quote  Post ReplyReply Direct Link To This Post Posted: 25-October-2017 at 1:37AM
Thanks, I've had David do work for me in the past. Not ready to spend $2K on a transmission for this project.
Thanks for all the input on this too!
