  New Posts New Posts RSS Feed - 1973 Torino front clip
grandpops4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Topic: 1973 Torino front clip
    Posted: 01-September-2018 at 6:16AM
Can someone send me a diagram of the 73 Torino front clip. I need to see what parts I might be missing. Thanks Grandpops4
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2018 at 6:25AM
I don't have a '73 Diagram handy, but I did post 72 diagrams over here:
These will give you some idea. I will see if I can dig up a '73 diagram
jhggtsf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhggtsf Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2018 at 8:04AM
Do these help? They are from an old Mitchells Manual, so they might not be as detailed as you need.
They got converted down to a lower resolution uploading to the forum. I can send you the original pages if you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2018 at 9:16AM
Please send me the originals. Thanks
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhggtsf Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2018 at 11:01AM
I sent you a PM, but the internal attachment size won't allow the full resolution scans.
This is a little better:
Post Options Post Options   Thanks (1) Thanks(1)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2018 at 8:58AM
Thank you for what you sent me but I'm still lost. Behind the grille and headlights are tabs which something connects to to hold them in place. What are those parts and where to they connect to for support( the core support?). This is what I need. Someone else ( a shop) removed the front clip and I don't know what he did with the parts or how it goes back together. Sorry for being dumb but I'm trying to learn. Grandpops4
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2018 at 10:42AM
Is this what you're looking for:
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2018 at 3:38AM
Yes thank you
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2018 at 8:00AM
in the above diagram... the parts #13A004 bolt to the headlight housing and to the core support if this is what you're asking?...
