1973 Torino tach harness question |
anchovieMAN
Member Joined: 19-January-2021 Location: Wisconsin Status: Offline Points: 70 |
Posted: 16-December-2021 at 9:31AM |
I’m converting my car to a sport cluster car and I was wondering if anyone had a picture of where the grommet for the extra harness goes for the tach and what size hole I need to cut to fit the grommet. Thank you
Jayden
Eliteman76
This was off my original 4 speed Q code.
Don't quote me but here is the openings. Large circle opening is the clutch rod. Directly above that is the brake booster square opening. To the right {Technically to the left, towards the driver's side} the two smaller holes are for electrical. Large square is one of the two openings for the bulkhead connectors for the main wiring harness. |
Pondering: #99Problems |
Eliteman76
I need to get my car out tomorrow and firre it up to let it run. I'll see if I can get pictures as long as the weather isn't really nasty out. Been in low teens all week here with some winds and not fun being outside in the cold!
