  New Posts New Posts RSS Feed - 1973 Torino Voltage Regulator Wiring
grandpops4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Topic: 1973 Torino Voltage Regulator Wiring
    Posted: 10-November-2017 at 7:42AM
Can anyone tell me the correct wiring for my Voltage Regulator.
"I" what color wire from the wiring harness.
"A" Same.
"S" Same.
"F" Same.
Thanks Grandpops4
gm
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 10-November-2017 at 11:25AM
"A" Same.
"S" Same.
"F" Same.
Thanks Grandpops4
The wiring will be different depending on what amperage alternator your car has, and if you have sport cluster or not. Need more info.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 10-November-2017 at 10:09PM
85 amp alternator and yes I have a sport cluster
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 11-November-2017 at 1:06AM
This may help, although this image is from a '75 shop manual. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 11-November-2017 at 8:05AM
The diagram posted above by aquartlow, is the same for a 73. You need the diagram for an ammeter charging system.
The I terminal is not used on a sport cluster car.
The A terminal is battery power to the regulator. The wire is yellow with white dots. It goes to the battery power side of the starter solenoid, and usually has a fusible link at the end.
The S terminal is key power from the ignition switch.  It should be green with a red stripe.
The F terminal goes to the Field terminal on the alternator. It should be orange with a light blue stripe.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-November-2017 at 4:48PM
yes fig. 2 on the right is the sport cluster wiring...
This page was generated in 0.269 seconds.
