  New Posts New Posts RSS Feed - 1975 Cougar
1975 Cougar
 Post Reply Post Reply Page  <1 3456>
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2016 at 6:50AM
Originally posted by mcford mcford wrote:
If you need to touch up any of the white trim, SEM Phantom white is a dead nuts match.
That's good to know! :)
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2016 at 6:56AM
Finally got my new center caps. Beautiful pieces from Scott Drake...
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2016 at 7:05AM
those are nice Thumbs Up
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2016 at 8:22AM
I know I have said this before... Very pretty Kitty! :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2016 at 11:39AM
Thanks guys!
A few new things...
Big thanks to californiajohnny for getting me an OE antenna! Now I can listen to the same radio station the entire way to work! lol
Then some progress on getting the climate control system working again. Here's why the blower motor didn't work....  41 years of debris and rust lol.
Of course the blower mount plate was badly rotted away....
So I made up a new one and painted it....
Then installed it into the lower AC blower housing along with the replacement motor. I soldered the harness wires from the original motor into the new one so that on the outside it still has factory connections....
Hoping to get it installed this weekend and then see if the AC blows cold!
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2016 at 2:21PM
Nice work!  Man that old motor was seriously rusted!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2016 at 2:25PM
I laughed when I finally pulled it. I didn't really want to pull the blower case so I was trying to "jump start" the blower motor with a battery charger, thinking maybe the brushes were just frozen. Nope!  It was packed solid with acorns and debris, the motor was rotted apart from the cage, and the lower part of the motor case was completely rotted away. Lightning couldn't have jumped this thing, lol.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2016 at 3:08PM
nice work! I have owned a lot of rusted up mid 70's fords. But that motor is a winner! great job on the repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2016 at 3:25PM
It was the original motor too, with the 75 date stamp and all.... :)
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2016 at 3:45PM
41 years ago is a long time....... I remember when those cars were new in the dealerships.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2016 at 4:35PM
sal, that antennae looks good on there Wink glad to help! yeah that motor was bad, mine was frozen too! i figured i would be buying a new one too so i had nothing to loose so i sprayed PB blaster in the bushings on mine and tapped on the shaft and worked it slowly with visegrips, more PB then when it started to turn, i jumped it with the battery charger on 200 amp start mode Big smile it freed up and is still working fine in my car! Big smile i did buy a VDO replacement motor for my celica, it blows better than the original ever did Thumbs Up
 BTW, nice work on that plate!!! looks factory stockClap
Edited by californiajohnny - 24-June-2016 at 4:37PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2016 at 11:16AM
Little more work done...nothing spectacular.
My car has the typical rotted out battery tray portion of the inner fender. The battery was being held down with a bungee cord and sitting on a piece of wood stopping it from falling through, lol. I really didn't want to track down a clean inner fender, pay a zillion dollars for it, and take the car apart to change it. So I decided to make a patch section.
Here is what I was starting with....
Here is the patch section I made. I used heavy gauge aluminum. Yes, I cut the entire thing out with a hand nibbler. Yes, my hand was sore for days afterwards, lol.
Then installed into the car, with a repro battery tray in place.....
I have a little more finish work to do on it, then I will paint it all black so it blends in.
I also got the A/C up and running.... :)
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2016 at 3:41PM
wow! nice work Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2016 at 8:38AM
Real nice work! Just get that aluminum coated because that battery will make short order of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2016 at 5:24AM
Got a factory radio back in the dash! Looks great and works great. 8 track player works too!
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2016 at 5:53AM
Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2016 at 5:57AM
I'm going to redo all the silver trim on the dash next I think.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2016 at 11:59AM
Well I couldn't resist redoing all that worn off silver trim with that nice OE radio in there now!
I used high temp aluminum paint, since it is extremely shiny and was a nice match. Applied it very carefully using a q-tip. I think it came out nice!
Before pics...
After pics....
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2016 at 12:23PM
I used a paint marker on mine that works great too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2016 at 1:21PM
Looking great!  You have really detailed this car well so far.
