  New Posts New Posts RSS Feed - 1976 Ranchero GT
1976 Ranchero GT
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Topic: 1976 Ranchero GT
    Posted: 27-June-2021 at 5:59AM
Just bought this on Friday, runs good. Not 100% confirmed yet on engine: 351C/ 351M/ 400...
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 6:08AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 6:10AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 6:12AM
I have not done a single thing to it yet other than put 5 gals of premium gas in it to get it home to Lexington. It still has the old window tint on it that has turned purple.Geek
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 6:50AM
Any 2 or 4 marking on the head corner? If no, I say 400. The bar cast in block near distributor I believe is M.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 6:51AM
My 400 has same block ledge and no id on heads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 6:52AM
Congrats, and enjoy that new project. I don't think it's one of those three engines, so I'll guess it's a BBF.
How many valve cover bolts are there, and better describe the thermostat housing? The block in front of the driver side head doesn't look familiar to me, and I don't know big blocks well. That reminds me of the 400 block, but I don't see enough of them there to be sure. If the thermostat housing is on the block, I'd bet it is a 351M or 400(with 8 VC bolts).
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 6:55AM
   What is the VIN? Fourth symbol says what factory sold it with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 7:12AM
   I didn't even think of 385 series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 8:15AM
The fourth number in the vin is a "8". The 1970-1979 Ranchero breaks down the 3rd and 4th digits as: 47=Ranchero 500, 48=Ranchero GT, 49=Ranchero Squire. My vin shows "48". It has 8 bolts on the valve cover which should be 351C/351M/400.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 8:25AM
not a 429/460. the Upper radiator hose is coming up out of the block, not forward out of the intake.
335 series engine. Look at the motor mount. Is it a 302/351W/C style or a 351M/400 style.
351C can alsoo be determined by intake width and block height at distributor to manifold area.
Cool car!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 8:31AM
Very good, 8 VC bolts. The block is taller than a C, so it has to be the 400 or 351M. The height between the block timing cover area, up to the heads is more than a 351, and much more than a 302.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 8:33AM
Kinda like playing "Name That Tune!" with engine details. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 9:37AM
Yes, I know my stuff very well, but remembering what other things looked like from 45 years ago, that's hard. I have a 400 block buried in my garage, but I haven't seen it in almost 20 years.
Nowadays in modern times, you use a phone to keep pictures of everything, and you can search through them easily later on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 10:54AM
Sorry. The fifth digit is the letter designation of the engine. S code is a 400.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 11:00AM
   Also, on the block above the starter is the casting number.  And next to the oil sending unit is casting date and foundry info. My block was cast at the Michigan Casting Center on October 21, 1977.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 11:02AM
    A cell pic is easy to get without jacking the car up. Just do it when the engine is cool.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 11:51AM
I have a really nice grill emblem for a Ranchero
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 1:52PM
congrats JT! looks the be a 351M but could be a 400
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 2:24PM
Block numbers won't help as 351M and 400 use the same casting. Same goes for heads and intake/exhaust manifolds.
Cleveland went extinct in 74, so unless it was swapped in it's M/400.
Swapping in a C in a M/400 car also requires a trans swap, (or possibly a bell/TC swap at minimum) as well as at least a partial exhaust system.
Edited by Big Bird - 27-June-2021 at 2:29PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2021 at 3:46PM
Fifth digit in the VIN is and "H" which is a 351.
