  New Posts New Posts RSS Feed - 1976 Torino...again
1976 Torino...again
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2017 at 1:47AM
It has 130K on it. The transmission is brand new (5 miles when I got it, now has about 100) and the engine had a valve job, lifters/cam/springs (Summit), timing chain and oil pump a number of years ago. I am rebuilding the carb, installing a spare starter and the old radiator out of my '74 Cougar next week and this car could be driven pretty much anywhere. The dual exhaust is in great shape but the mufflers are loud. Like a pair of old Smitty's, loud. They bark when you start it, bark when you blip the throttle and blat when you get on it. They get almost silent when you are just cruising along or coasting, but can wake the dead when you accelerate. I have a video of it idling below.
Edited by unlovedford - 04-May-2017 at 2:15AM
1972 GTSquire Wagon
1976 Torino (2)
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2017 at 2:00AM
sounds like my kind of car, nice and obnoxious LOL
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2017 at 2:10AM
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2017 at 2:20AM
LOL!!  sounds like the fiberglass has burned out of those a long time ago, reminds of a dodge truck I used to have when I lived in yuppieland s fl, it would set of car alarms on start up lol
Torino_Chris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torino_Chris Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2017 at 2:52AM
Shocked That sounds like a big block race engine or something Big smile
1988 Porsche 944
"...what's it all about, guess it just reflects my moooood..." ;) (The Rolling Stones)
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2017 at 6:07AM
I think if you look closely you'll find there are no pipes between the manifolds and the mufflers. On second thought, are you sure it even has manifolds?
Edited by stanman - 04-May-2017 at 6:11AM
M Casey Stock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2017 at 1:48AM
That's the way mine drives, just like a regular car, nice smooth ride, seems a little soft in tight curves, but that is to be expected with a soft ride suspension. After the steering head upgrade, it's easy to forget you are in a 40 + year old car that hasn't had all the latest suspension mods. I might upgrade my sway bars to give a little better handling on the back roads, but I'm happy other than that.
You might try the color match spray can system on those primer spots, a single stage paint like what came originally on the car might not be noticed as being thicker than the rest of the paint. Just a thought, since the rest of the paint looks like it will polish up nice.
Now for that exhaust, LOL, yep, that's loud. Here I am struggling to figure out why my flow mast 40's are not as loud as others I hear and you are waking the dead with yours. I don't know what is wrong with mine, but yours seems to defiantly be burned out, doesn't really fit the look of the car.
1975 Gran Torino, Copperhead
http://forum.grantorinosport.org/75-gran-torino-soft-restoration-copper-head_topic15137_post169060.html?KW=#169060
twintornados View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twintornados Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2017 at 10:00AM
Sounds just like when I was a teen and my 1969 Ford LTD XL sportsroof I bought needed a motor and trans so I put a 351W / C4 from my 1970 LTD after the frame broke and all I had money for was 2 three foot lengths of flex pipe and 2 thrush mufflers wired to the frame....
In other words...COOL AF!!!!
1974 Gran Torino Elite...gotta love them big Fords...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2017 at 11:04AM
My Thunderbird needs to sound like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2017 at 12:14PM
Randy, I'd trade exhaust!
Casey, my gold '72 460 has 2.5 inch aluminized exhaust, H pipe and flowmaster 40. Sounded great but quieter than I expected when I got it home from Allan's. The H pipe calmed it a bit. However, when we installed the cam setup, it really added a great metallic upgrade. I absolutely love it, but driving 70 on the interstate for several hours is a wee tiring. Keep in mind that I had the pipes run out to the sides behind the rear tires, so it is a bit louder. When I install the D0VE heads, I have been told it will sound even more aggressive. I shot a video, but the sound is very distorted when I rev the engine, due to the sound volume of the exhaust. This '76 is a 351W with a small Summit cam set and full exhaust in great shape, but the glasspacks are probably empty now. No holes, just no fiberglass left in them. I may install the 17/18 inch Bullits this week to help the look of the '76, but you are correct, this sound is not a good match for this car. Perhaps a pair of Turbo mufflers I have on hand?
Edited by unlovedford - 07-May-2017 at 12:31PM
1972 GTSquire Wagon
1976 Torino (2)
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2017 at 12:24PM
Well the D0VE heads should up the CR a bit if its on D3's right now....if you want it to sound real aggressive though you need true dual 3" pipes with dynomax race bullets Wink
Thats the way forward for big block exhausts! Or just fender dumps.....
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2017 at 12:25PM
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2017 at 12:29PM
It is actually far more loud and hollow sounding than the video illustrates. It literally bellows. I had a '72 with a 302, headers, 2.5 inch pipe, 40's and full exhaust out the back with 3 inch tips. It sounded good, but not nearly as loud as this car. Pipe placement, displacement and pipe diameter play a key role.
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2017 at 2:03AM
Bullits and Turbo mufflers will be great upgrades. When I said "burned out", I was meaning the glass packs were empty.
I have 2.25 exhaust. My car had single 2.25 on it down the passengers side, my parts car used to have duals 2.25 but the passengers side was missing. I cut the factory cross over right where the drivers dual pipe would pass by and used the drivers side pipe off the parts car back to where the factory muffler location is. I used a hole saw and cut a hole in the drivers side pipe in line with the stub of the factory cross over and welded the factory cross over to it, making a "H" pipe, kinda. It's more like a "X Y H" combo LOL. It does the same thing for balancing the two sides and getting rid of the trashy pop back, but I was beginning to wonder if that is why it is so quite in comparison to other Flowmaster 40s I've heard. The 40s are clamped on at the factory locations with 2.25 turn downs just ahead of the rear differential. I should shoot you a picture, it doesn't look bad, it's just different.
Edited by M Casey Stock - 09-May-2017 at 3:53AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 10:40AM
Have decided to either sell this car or the gold '72 Formal. Whichever sells, I'll keep the other. Price on this one is $3,500 or close offer. I would take $7,800 on the gold '72.
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 2:09PM
As nice as this '76 is, I hope it's the one that goes first.  Would love to see you finish the '72.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 2:38PM
X2 what vince said
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 3:07PM
I love the '72 and have really put a lot of love into it. However, I have a chance to buy one of my dream cars and need some space. Just thinking about it makes me giddy.
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 3:39PM
There'll be other Dodge Omnis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 3:41PM
LOLLOLLOLDead
