  New Posts New Posts RSS Feed - 1979 Ford Thunderbird
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2017 at 12:56PM
if i'm correct... you should be able to use a stock distributor from a 351w out of like a ford truck late 70's -mid 80's???as long as it has the vacuum advance on it should plug into your dura spark box in the 90's they didn't have the advance it was computer controled Angry
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2017 at 1:27PM
the blue strain relief on the module is an indicator, i'd make sure that matches the model year of the car 1979 and source a 351W distributor for 1979 also
here's chart to help coordinate components
T-Bird_79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bird_79 Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2017 at 9:03AM
Module with the so-called blue grommet, which I have, is correct one for the 77-79 cars. If this will go to the point of actually swapping engines, definitely easiest way is to buy a correct distributor for 351W.
Thanks for the link! Useful info!
Andris
1977 Opel Commodore Coupe or euro personal luxury
1969 Vauxhall Viva or small American
1978 Moskvitch 412 or Soviet rally
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bird_79 Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2017 at 9:08AM
yeah the bracket was on it it probably works i can test it and see?
Yes, thank You, if You could test it it would be great. And maybe You can take a picture of it?
Andris
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2017 at 12:16PM
Wink will do
