  New Posts New Posts RSS Feed - 1979 LTD II Engine mount issue!
stevewarden0 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevewarden0 Quote  Post ReplyReply Direct Link To This Post Topic: 1979 LTD II Engine mount issue!
    Posted: 21-June-2018 at 2:29PM
Hi,
I have an problem with the way the engine sits in my LTD II.
On the drivers side there is only 1/16 of an inch gap between the exhaust manifold and the steering box. The engine mounts look OK but not sure! Has anybody else had an issue like this?
What I have noticed when I drive the car is that it feels like something is against the body on acceleration, on overrun it is smooth (partly why I suspect mounts)
If it is the mounts anybody any suggestions for best replacement - performance or standard?
 And what type of a job is it to replace all the mounts?
Thanks
Steve
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2018 at 3:40PM
does the engine sit level or is it leaning over like it's passed out drunk?
pics?
do you have a local transmission shop that can look at it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2018 at 4:04PM
sounds like it could be a broken motor mount? what engine do you have???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2018 at 3:03PM
Mounts are easy, if you can find them. FYI, if you have the 302, it sits low and close to the steering box even with good mounts.
This page was generated in 0.080 seconds.
