  New Posts New Posts RSS Feed - 1979 LTD II Engine mount issue!
stevewarden0 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevewarden0 Quote  Post ReplyReply Direct Link To This Post Topic: 1979 LTD II Engine mount issue!
    Posted: 21-June-2018 at 2:29PM
Hi,
I have an problem with the way the engine sits in my LTD II.
On the drivers side there is only 1/16 of an inch gap between the exhaust manifold and the steering box. The engine mounts look OK but not sure! Has anybody else had an issue like this?
What I have noticed when I drive the car is that it feels like something is against the body on acceleration, on overrun it is smooth (partly why I suspect mounts)
If it is the mounts anybody any suggestions for best replacement - performance or standard?
 And what type of a job is it to replace all the mounts?
Thanks
Steve
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2018 at 3:40PM
does the engine sit level or is it leaning over like it's passed out drunk?
pics?
do you have a local transmission shop that can look at it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2018 at 4:04PM
sounds like it could be a broken motor mount? what engine do you have???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2018 at 3:03PM
Mounts are easy, if you can find them. FYI, if you have the 302, it sits low and close to the steering box even with good mounts.
