1979 LTD II Engine mount issue! |
stevewarden0
New Member Joined: 28-April-2018 Location: Canada Status: Offline Points: 6 |
Posted: 21-June-2018 at 2:29PM |
Hi,
I have an problem with the way the engine sits in my LTD II. On the drivers side there is only 1/16 of an inch gap between the exhaust manifold and the steering box. The engine mounts look OK but not sure! Has anybody else had an issue like this? What I have noticed when I drive the car is that it feels like something is against the body on acceleration, on overrun it is smooth (partly why I suspect mounts) If it is the mounts anybody any suggestions for best replacement - performance or standard? And what type of a job is it to replace all the mounts? Thanks Steve
Steve
does the engine sit level or is it leaning over like it's passed out drunk? pics? do you have a local transmission shop that can look at it?
sounds like it could be a broken motor mount? what engine do you have???
Mounts are easy, if you can find them. FYI, if you have the 302, it sits low and close to the steering box even with good mounts.
