250 electronic ignition |
unlovedford ![]() Senior Member ![]() ![]() Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 10142 |
![]() ![]() ![]() ![]() ![]() Posted: 30-September-2013 at 2:17AM |
I am considering swapping out my points distributor on my '72 wagon for a later model Duraspark. Does anyone know a quick and easy way to do this? I had thought about getting one for, say, an '81 Fairmont w/a 250 and mock up the wiring with a hidden box. Might have to swap the coils as well.
I just dislike points on a daily driver, and am trying to get the most out of my six. |
madmaxtorino ![]() Moderator Group ![]() ![]() Zombie Killing Training Instructor Joined: 04-August-2010 Location: Lawrenceburg Tn Status: Offline Points: 965 |
Allan
Great!! I didn't think they made them for a lowly 6.
GranTorinoSport ![]() Admin Group ![]() ![]() Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2273 |
Glad to see they make them, but I too am surprised frankly.
Webmaster |
Actually, just checked - Mallory makes the vacuum advance Unilite distributor for all the standard six's.
A much more expensive solution, but it is nice to know they offer them!
Webmaster |
am not r2 ![]() New Member ![]() Joined: 03-October-2013 Location: saratoga Status: Offline Points: 2 |
the mallory units are great...i have installed more than one. the oem units don't get proper lube in long service and wobble and need to be rebuilt. Napa sells rebuilts fairly cheap. Get one of those and a pertronix unit(and the matching coil). NEARLY AS GOOD,
Greg73Oregon ![]() New Member ![]() Joined: 23-February-2021 Location: Salem, Oregon Status: Offline Points: 20 |
You can squeeze a lot of ponies out of a six, without spending a lot of money!
This was my 1970 Maverick: 200 cid. |
GKF
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 3933 |
In Mavericks, early Falcons and early Mustangs the 200 was great. Not so much in the late 70s Granadas, Fairmonts and Mustangs, but they do have Duraspark.
Yes & No. The later heads had better flow through the "log" intake, but the compression went way-way down. I took a a 1976 head, put larger stainless steel intake/exhaust valves and milled 0.060 off the head. I also used 1.6:1 rockers (Jeep six banger). Stock rockers are 1.5:1.
Headers with dual exhaust. And, recurved a 1978 Dura Spark distributor.
I gutted the control module (was burned out), and mounted an HEI 4-pin module. |
GKF
Tweet
