Forum Home Forum Home > Powertrain Specific Forum > Six Cylinder Forum
  New Posts New Posts RSS Feed - 250 electronic ignition
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Topic: 250 electronic ignition
    Posted: 30-September-2013 at 2:17AM
I am considering swapping out my points distributor on my '72 wagon for a later model Duraspark. Does anyone know a quick and easy way to do this? I had thought about getting one for, say, an '81 Fairmont w/a 250 and mock up the wiring with a hidden box. Might have to swap the coils as well.
I just dislike points on a daily driver, and am trying to get the most out of my six.
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2013 at 10:25AM
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2013 at 2:35AM
Great!! I didn't think they made them for a lowly 6.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2013 at 1:28PM
Glad to see they make them, but I too am surprised frankly.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2013 at 1:30PM
Actually, just checked - Mallory makes the vacuum advance Unilite distributor for all the standard six's.
A much more expensive solution, but it is nice to know they offer them!
am not r2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote am not r2 Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2014 at 11:01PM
the mallory units are great...i have installed more than one. the oem units don't get proper lube  in long service and wobble and need to be rebuilt. Napa sells rebuilts fairly cheap. Get one of those and a pertronix unit(and the matching coil). NEARLY AS GOOD,
Greg73Oregon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2021 at 3:54AM
You can squeeze a lot of ponies out of a six, without spending a lot of money!
This was my 1970 Maverick: 200 cid.
GKF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2021 at 3:12AM
In Mavericks, early Falcons and early Mustangs the 200 was great. Not so much in the late 70s Granadas, Fairmonts and Mustangs, but they do have Duraspark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2021 at 8:47AM
Yes & No.  The later heads had better flow through the "log" intake, but the compression went way-way down. I took a a 1976 head, put larger stainless steel  intake/exhaust valves and milled 0.060 off the head.  I also used 1.6:1 rockers (Jeep six banger). Stock rockers are 1.5:1.
Headers with dual exhaust. And, recurved a 1978 Dura Spark distributor.
I gutted the control module (was burned out), and mounted an HEI 4-pin module.
GKF
