302 Mexican Block ? |
Fordman53955
New Member Joined: 05-October-2005 Status: Offline Points: 9 |
Posted: 29-March-2006 at 10:15AM |
I just seen this 302 it had two "knobs" cast into the block one on either side. They are about 1-1.5" around and stick out about 1.5-2". From my book it says that this is a mexican block. Did they ever make a standard block with the "knobs" cast into the block. The engine is in a 72 Torino but not sure if it's original. If this is a mexican block is it worth saving. The car was suppose to go up for sale and I don't want to do an engine swap if a 5.0 block is as strong. Thanks |
ponyman89
New Member Joined: 28-October-2003 Location: Canada Status: Offline Points: 9 |
I was just talking to my freind about the mexican block he said that if they have the knobs they are mexican if not they are american "weaker" block
1979 thunderbird 302,c4
1974 ranchero 400,c6 |
sdjiricek
New Member Joined: 30-January-2007 Status: Offline Points: 1 |
should say "hecho en mexico" somewhere on the casting. The heads will also say this when you take the valve covers off.
