  New Posts New Posts RSS Feed - 302 No Start
302 No Start
KingMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingMe Quote  Post ReplyReply Direct Link To This Post Topic: 302 No Start
    Posted: 14-October-2017 at 3:00AM
 She turns over but no start. could this be the problem?
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2017 at 3:20AM
That looks like your positive coil wire....definitely need that hooked up to make the coil work.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2017 at 3:58AM
yes, what sal said!^^^^
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingMe Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2017 at 10:31AM
I tested coil and wires, seems to be working. distributor shifting left to right when I turn it could that be an issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2017 at 12:19PM
As in, center shaft wobble side to side inside the distributor?
If so, you need a distributor.
