  New Posts New Posts RSS Feed - 351 C motor mounts
351 C motor mounts
bdaugette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdaugette Quote  Post ReplyReply Direct Link To This Post Topic: 351 C motor mounts
    Posted: 08-September-2018 at 1:54PM
Motor Mounts for a 351C. Did anyone ever find the correct motor mounts for a 72 351C??
Bill Daugette
72 GTS 351C 4V
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2018 at 2:40PM
as far as I know any 302/351w/351c is all the same for our cars.
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2018 at 12:29PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdaugette Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2018 at 1:46PM
I have tried the 2371 on the right side using “Pro Torque” and it doesn’t fit. Today I tried the 2370 on the left, it bolts up to the block.   I tried the 2370 on the right and it bolts up, but I am afraid that it is offset a bit, and will not mount the engine correctly. Have to wait until Friday to check.
Bill Daugette
72 GTS 351C 4V
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2018 at 2:32PM
Mounts are different left to right. A LOT of the aftermarket ones were made wrong a few years ago.
Block side holes were too close together and if you bent them to fit, they won't hit the frame right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2018 at 3:42PM
i'd trust / try Anchor brand, they've been around long enough
late-comer copies have probably used the same part numbers for easy cross reference and substitution raz-mataz
This page was generated in 0.031 seconds.
