  New Posts New Posts RSS Feed - 351 CJ Engine
351 CJ Engine
Scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott Quote  Post ReplyReply Direct Link To This Post Topic: 351 CJ Engine
    Posted: 28-July-2013 at 3:20PM
I found a complete 1973 351CJ engine.Needs freshened up but did run when he pulled it.Does't have orig.carb but is complete carb to pan.How much is it worth? Any suggestions would be great.
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2013 at 3:57PM
HEADS have 4 stamp, Block is likely a 2bolt in 73. All 351C's are the same so the CJ part you are basically buying the heads and intake. If it is complete maybe 500 as a good rebuilder
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2013 at 6:07AM
From what I remember a 351CJ was called a CJ because it had 4 bolt mains no matter what year???????Anyone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2013 at 6:17AM
All 2 bolts can be tapped for 4 bolt mains. Blocks are  identical. Some even claim the 2 bolt is better by not weakening the main caps with  the extra 2 holes.
Other than heads exhaust and intake the 73 did not have the 4 degree cam timing delay for emissions yet like  the 2v versions.
iangj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iangj Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2013 at 11:06AM
'73 still had 4 bolt mains. Smaller valves and a wee bit less cam compared to '72. The intake will have provision for the EGR port. Exhaust manifolds are the same. The rest is the same.
The CJ had a 4-6 degree retard built into the cam gear. This can be easily fixed with a good quality gear & chain replacement.
Auto cars had single points, 4 speed had dual points.
Edited by iangj - 05-August-2013 at 11:09AM
Ian Glyn-Jones
Fonthill, Ontario, Canada
'72 Montego GT Q Code
Montego GT Registry
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2013 at 2:56PM
My '72 CJ has the 4 bolt mains. My '74 CJ has the 2 bolt mains. 1973 was the last year for the CJ 4BM blocks, but like others have said, a 2BM block can stand a lot of HP.
1972 GTSquire Wagon
1976 Torino (2)
This page was generated in 0.059 seconds.
