351c 4v Fan |
Fritz
New Member Joined: 10-June-2020 Location: Marysville Wa Status: Offline Points: 19 |
Posted: 02-February-2021 at 6:26AM |
Any advise to which fan would be best for my 72 GTS 351c 4v w/AC?
fritz
handsofstone
I still have a flex fan on mine. 400 with A/C. I think it is 5 blade. Zero overheating issues on the hottest days. Then again, my evaporator needs to be replaced.
Exodus BKG
New Member Joined: 10-June-2021 Location: Seattle Status: Offline Points: 21 |
Electric Derale w/ Pulse Width Modulator.
Remove the mechanical burden on your motor of a Fan and or Fan Clutch. I switched to electric a long way back, way better cooling controlled power. Less load on your motor. Derale .c They have all sorts of stuff
