  New Posts New Posts RSS Feed - 351m/400 header problem
Mizzou.Mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mizzou.Mike Quote  Post ReplyReply Direct Link To This Post Topic: 351m/400 header problem
    Posted: 29-September-2015 at 9:39AM
The only headers I can find for this are the shorty sanderson headers but they are over 500 bucks. Does anyone know if the 351m headers for a 78 truck will work on a 1974 Torino Elite?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2015 at 4:28PM
good question! do the trucks have the steering box in front of the cross member or behind it? i don't remember
Mcn33ri0N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mcn33ri0N Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2015 at 11:11AM
Does any one know what headers fit on my 1975 ford Torino elite it has a 351 m known a s351 modified considered a 400 but it say 351m, and ford Torino has a automatic tranny, and the steering column is behind the cross member
McNeer
torino75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino75 Quote  Post ReplyReply Direct Link To This Post Posted: 25-December-2015 at 2:24PM
Hi, unfortunately the only direct fit bolt-on headers that fit on this body / engine combo without clearances issues are the hooker super competition headers model 6125HKR which List at $543 this what i had to go with, but somewhat got lucky and found a lightly used set off ebay and saved like $200 maybe you can find a used set or spend the money on the hookers or you can custom make them $$$ if you find another direct bolt-on, please post it!!!
Good luck,
Syl
The Torino Kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Posted: 26-December-2015 at 4:31AM
Yes the info above is correct, I have a set Hooker Super-comps on  my 73 with a 351M-400 in it (don't ask..lol) and the fit is great.
1973 Gran Torino Sport CJ 351
'Q' code 63R body
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-December-2015 at 7:06AM
truck headers have way too much drop in the tubes, the collectors would be on the ground if they fit in the chassis at all
351M & 400 are virtually indistinguishable from the outside, they use the same headers
if you have the valve cover decal read it carefully, it will specifically list the displacement separate from the engine family
