351m intake front air injection question |
The Torino Kid
Senior Member Joined: 23-November-2003 Location: United States Status: Offline Points: 250 |
Posted: 30-September-2018 at 10:57PM |
So I got an intake manifold that I've been looking for and the only thing wrong with it. It has has a dime sized hole underneath the intake where the air injection crossover connects from one side to the other. I am not using air injection so my question is "would welding it closed be advisable since it's exposed to the lifter valley and oil?"
Second question is "should I block off those air injection ports in the head with some thin sheet metal or high temp jb weld? Tia |
1973 Gran Torino Sport CJ 351
'Q' code 63R body |
what heads? are the passages open and functional through the heads even though you're not using the system? do you have the heads that have tapped holes in the front back that take the plugs to close them off?
It's probably a good idea to fix that hole in the intake. I don't think you have to block off the head passageways but if they are threaded it'd be a quick and easy fix.
the Thermactor / EGR / A.I.R. / whatever you want to call them / passages in the front intake face of the smog heads are irregular shape, like the coolant passages in Windsor heads IIRC a pic of the heads would help generate the best answer
BTW there are turkey pan gaskets for each, with & w/o the passage, would the blocked off turkey pan solve the problem? |
The Torino Kid
'Q' code 63R body |
The Torino Kid
I'm getting the intake repaired at the machine shop as I type this.so hopefully I'll get it back by Fri.
'Q' code 63R body |
you may still need the gasket with the passage holes to seal the heads ;) Edited by Rockatansky - 02-October-2018 at 2:51PM |
i'm curious as to why it had a hole in the bottom side in the oil galley???
