351M vs 351W Fan & Shroud |
torinomike650
Senior Member Joined: 03-March-2019 Location: Palo Alto, CA Status: Offline Points: 997 |
Posted: 05-April-2019 at 7:03AM |
I am pulling a 351M/400 out of my 1976 Gran Torino and putting in a 351W. Does anyone know if I can use the same fan and shroud? Or do I need to replace one or both? Thanks!
--Mike
1974 Ford Gran Torino |
Admin Group GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5849 |
The shrouds were the same, only the big block cars used a different shroud. The fan should swap, too but just double check the spacing for the fan in the shroud. There are lots of aftermarket options for fans that will fit fine.
Regul8r 2
Admin Group Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
same shroud.
I swapped out an entire engine, picked a 351W fan spacer from a local junkyard and the fan was right where it needed to be |
Owner- www.CaNDeCustoms.com |
torinomike650
Thanks(1)
Awesome, thanks!
