  New Posts New Posts RSS Feed - 351M vs 351W Fan & Shroud
torinomike650 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Topic: 351M vs 351W Fan & Shroud
    Posted: 05-April-2019 at 7:03AM
I am pulling a 351M/400 out of my 1976 Gran Torino and putting in a 351W. Does anyone know if I can use the same fan and shroud? Or do I need to replace one or both? Thanks!
--Mike
Mike Abraham
chase_the_sun_2_cali@yahoo.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2019 at 12:22PM
The shrouds were the same, only the big block cars used a different shroud.  The fan should swap, too but just double check the spacing for the fan in the shroud.  There are lots of aftermarket options for fans that will fit fine.
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 06-April-2019 at 6:52PM
same shroud.
I swapped out an entire engine, picked a 351W fan spacer from a local junkyard and the fan was right where it needed to be
Owner- www.CaNDeCustoms.com
Post Options Post Options   Thanks (1) Thanks(1)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2019 at 7:40AM
Awesome, thanks!
Mike Abraham
