  New Posts New Posts RSS Feed - 351w timing pointer
351w timing pointer
73GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Topic: 351w timing pointer
    Posted: 18-April-2017 at 5:42AM
Hey guys,
I know someone knows what I need. I can't find a pic and have no idea how to mount this timing pointer. It goes on the pass side of the timing cover. There has to be something that goes between the cover and the pointer and I don't know what that is. Here's a pic of the pointer. The dipstick goes behind this bracket and between the holes. It needs to stand off the cover.
Jim
NorthElite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2017 at 7:18AM
It comes under water pump bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2017 at 7:53AM
Ah, the timing cover is different. I'll have to make some sort of spacer. Can you measure the timing chain cover behind the bracket, the area I marked? I'll make a spacer. Thanks!
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2017 at 6:58PM
It is not easy for measure it anymore, because my engine is installed. But is your main problem different harmonic balancer length?
You also may need to fit pulley lines fit together and it depends what kind pulleys you are using.
I'm not specialist in this one. In my project I used one spacer to fit pulleys correct line. And just because I select wrong length to harmonic balancer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2017 at 1:47AM
I dug thru my parts stash last night and found the right timing cover. So, I get to pull it all back apart. Anyway, thanks for the pic. That was the help I really needed Thumbs Up
Jim
