Forum Home Forum Home > Powertrain Specific Forum > FE Block Forum
  New Posts New Posts RSS Feed - 390 GT engine
390 GT engine
ptac85 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ptac85 Quote  Post ReplyReply Direct Link To This Post Topic: 390 GT engine
    Posted: 25-June-2020 at 4:24AM
 In my 68 torino I have been told that it was an original 390 gt engine. In 1991 -long story short- I cracked the original block when something got sucked into the engine. There was some damage to the heads that I have been reassured on 3 occasions are simply cosmetic (Magnafluxed 3 times) I was sold a 360 block being told it was the same as my 390....and rebuilt the motor. Ran great. Early part of 2012 ish...I had a professional shop rebuild the motor and have had nothing but problems with it since. Now in 2020...I am having a professional repaint the car---and is telling me the engine is coming out for the paint job. Its a foregone conclusion in my mind that the engine is being replaced or rebuilt. My questions are----Should I keep the gt heads...or go lighter weight aluminum? Recommendations? Also...any recommendations on a rebuild shop in the twin city metro area would be appreciated. I want this to be the last time I have to invest time and money into a rebuild.
tp
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-June-2020 at 5:27PM
i think the block is the same? 390 was stroked more??? also a 428 was available in the FE seriesBig smile
 from what i understand you want to go through the heads with good guides and hardened seats good seals and springs stock they are kinda junk but with proper upgrades they are great! aluminum will flow better and are lighter and will probably have all those good upgrades already depending on what level you buy...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 26-June-2020 at 7:20AM
360 is a 390 block with a 352 crank. Hopefully all you have is the bare block from the 360, and not the entire short block.
(That would explain why you were unhappy after the rebuild, 360 is a Lo-Po truck motor with next to no compression-the 351M of the FE world)
Ford wanted to make one less part and the 352 had a bore 0.050 smaller than a 390.
Aluminum heads and intake would be the way to go if you are not happy with your current heads.
intake alone will be a massive savings in weight.
I don't think the GT got "special" heads anyway.
Rons73 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rons73 Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2020 at 8:26AM
If your stock heads need any work, money wise it may be advisable to simply get new aluminum for the weight savings and better flow out of the box.
390gt heads do have the staggered bolt pattern, which may affect exhaust options.  Otherwise not much difference vs the other standard FE heads.
I don't know your plans but if you are not worried about keeping it original, I would go aluminum heads and intake, as the stock "S" 390 GT manifold was pretty poor for performance as cast.  If you want to keep things original, you can improve the heads and intake with porting, but this may get costly if you have to pay someone to do it.
If I was doing it non-stock for a fun street application:
Stock block (bored as required)
390 crank and rods (for ease of availability unless you wanted a stroker)
cast pistons supporting a 10:1 ish compression ratio (if you want nitrous or +6000 rpm go forged)
Edelbrock Streetmaster or Performer RPM intake (based on availability/cost/performance)
Edelbrock Performer RPM 390/428 heads
750 sized vac secondary carb
Competition Cams Extreme Energy 218/224 hydraulic flat tappet cam(apparently my old 268 fav is no longer produced?)
Headers to fit chassis and 2.5"dual exhaust
There are other brands and options, I picked these as available examples of stuff that has worked for me in the past.
If you want a serious FE, check out Survival Motorsports for ideas...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2020 at 9:41AM
Ed heads are on sale
https://www.summitracing.com/search/department/engines-components/section/cylinder-heads/part-type/cylinder-heads/make/ford/engine-family/ford-big-block-fe/brand/edelbrock?N=brand%3Aedelbrock&SortBy=Default&SortOrder=Ascending
Comp 268H for FE is still going, it's just the Edelbrock, Comp, Crane and who knows how many other web pages are so Censored they're unusable.
i go directly to Summit and hope for the best. works so far
excellent street performance / daily driver cam for stock driveline combos
https://www.summitracing.com/parts/cca-33-224-3/make/ford
is the Streetmaster a single plane?
i wouldn't pair it up with a 268 cam, i'd use the 7105 or equivalent dual plane
https://www.summitracing.com/parts/edl-7105/make/ford
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2020 at 2:17PM
Don't freak out if you see the pistons with .080 over stamped on them. 390 starts as .050 bigger than a 352, and some 390 rebuilder pistons are marked like they are 352 pistons .080 over, instead of 390 .030 over.
Good for a WTF moment the first time you see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rons73 Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2020 at 4:13AM
Great news about the 268H! Wonderful truck and cruising cam. Very satisfying throttle response. Hard on tires...I mention the old streetmaster because it works surprisingly well with the FE iron heads, and is often available fairly cheaply. Something to do with port velocity and swirl.  Works really good with nitrous too Wink May not be as pronounced with the aluminum heads. But it is really hard to beat the Perf RPM, always a good choice.
Had not seen the pistons marked that way, good tip. Would definately be scrambling for the mic once noticed lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ptac85 Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2020 at 4:59AM
It is just the 360 block as everything else was transplanted from the stock 390 when I built it in 1991. When I had it "professionally" rebuilt in 2010 ish....they did away with the cast iron intake and distributer set up. While the car itself is 95% stock... Since I cracked the original block...I am willing to go with what is best in 2020 ----over what was best in 1968. I appreciate the feedback and think Alum heads are the way to go and already run an edelbrock intake. I am looking for a driver with a nice idle that can run the various vacuum options on the car ---but I wouldn't mind A LITTLE bit of attitude. I just have to find the shop that can help me with the build. Yes I could do it....but I want someone else to blame if something went wrong! Thanks again
tp
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2020 at 7:10AM
268H has that little bit of attitude and makes vacuum Wink
works best with stock converter and gears, drop it into a more aggressive combo and it gets lost
you're near Tim www.tmeyerinc.com Meyer, maybe he can point you to a shop as he's busy doing .... something
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2020 at 7:43AM
i'd say 268, 270, or a  280 max! will have a good sound, good vacuum, and good off the line streetability, and a dual plane intake! aluminum heads, 2 1/2" dual exhaust, should work out greatWink
Hiriser75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hiriser75 Quote  Post ReplyReply Direct Link To This Post Posted: 24-October-2020 at 1:11PM
If your in Minneapolis area, machine shop called R & R Machine is a good ford shop.
  ALso, may check on the FE Power.net forum.  Jay Brown in Minnesota is a FE specialist.
Hiriser75
