400 vac line help? |
green74xr7 ![]() New Member ![]() Joined: 03-September-2013 Location: oregon Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 09-September-2013 at 6:05AM |
I have a 74 cougar xr7 with a 400 engine. Can anyone tell me where the hoses from the vac tree on the firewall need to go? I have all but one hooked up. Thanks
unlovedford ![]() Senior Member ![]() ![]() Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 10018 |
Here is a picture of the '74 Ranchero I had with a 400 in it from the factory. Sorry for the bad shot, but perhaps it will give you some insight.
1972 GTSquire Wagon 1972 Torino Wagon 1976 Torino 1968 Cougar XR7-First batch 1972 Torino 460 1989 BroncoII/Jeeps/Titanimous Popeye and Brutus (Rams) |
legend onirot ![]() Senior Member ![]() ![]() METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 2891 |
It is odd the difference between 1 year on our vacuume tees. I would think that a Ranchero unit would not be so different from a Torino.
I agree. The ranchero tree is similar to mine but not exact either. I'm in a vacuum mess I think. The person I bought it from even has the pcv vac hooked up to the tree instead of the back of the carb. I have the carb spot for the pcv plugged. I tried the pcv into the carb spot and plugged off the tree where it currently is and the engine shakes. I can't find a diagram ANYWHERE. It runs ok I guess. Kinda hesitates when I punch it
Mine also had ac but its been disconnected. Maybe a vac line went there???
The Ranchero was an A/C, C6/400 with PS and PB. It is more of a tree with several ports closed off.
Tweet
