  New Posts New Posts RSS Feed - 400 vac line help?
400 vac line help?
green74xr7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote green74xr7 Quote  Post ReplyReply Direct Link To This Post Topic: 400 vac line help?
    Posted: 09-September-2013 at 6:05AM
I have a 74 cougar xr7 with a 400 engine. Can anyone tell me where the hoses from the vac tree on the firewall need to go? I have all but one hooked up. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2013 at 4:27AM
Here is a picture of the '74 Ranchero I had with a 400 in it from the factory. Sorry for the bad shot, but perhaps it will give you some insight.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2013 at 7:03AM
heres a pic of leela, my 73 torino.  I assume you meant this doo-hicky.
the far left and far right hose goes to the transmission.  the second one from the left goes to the little thingy on the intake.  as you see the second from the right is capped on mine.  hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2013 at 7:58AM
It is odd the difference between 1 year on our vacuume tees. I would think that a Ranchero unit would not be so different from a Torino.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote green74xr7 Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2013 at 9:17AM
I agree. The ranchero tree is similar to mine but not exact either. I'm in a vacuum mess I think. The person I bought it from even has the pcv vac hooked up to the tree instead of the back of the carb. I have the carb spot for the pcv plugged. I tried the pcv into the carb spot and plugged off the tree where it currently is and the engine shakes. I can't find a diagram ANYWHERE. It runs ok I guess. Kinda hesitates when I punch it
Post Options Post Options   Thanks (0) Thanks(0)   Quote green74xr7 Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2013 at 9:19AM
Mine also had ac but its been disconnected. Maybe a vac line went there???
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2013 at 10:11AM
The Ranchero was an A/C, C6/400 with PS and PB. It is more of a tree with several ports closed off.
1972 GTSquire Wagon
