  New Posts New Posts RSS Feed - 429/460 Mounts are these Crites mounts?
fordismyboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordismyboss Quote  Post ReplyReply Direct Link To This Post Topic: 429/460 Mounts are these Crites mounts?
    Posted: 16-February-2017 at 2:46PM
Bought these from a cool guy on CL, but don't know who made them and they do not seem to be 3/8" of an inch lower than stock, as some posts have indicated that Crites are lower. The fact that they appear to be the same lift as stock makes me think they are not Crites. The photos on the Crites site are too small to tell.
What do you guys think? Crites?
Do you think I should just use the stock mounts if I beef them up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2017 at 12:02AM
Those fabbed up mounts look kinda skewed to me(angled), I would rather use stock mounts if they are in good condition. Just remember, most headers and aftermarket oil pans are made/designed off of measurements using the stock mounts. Just my honest opinion though.
MarkGubinski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkGubinski Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2017 at 1:46AM
I agree. Those fab mounts look rather wonky.
72 Gran Torino Sport 514
10.33 @134 @3600lbs.
2 Time Milan Dragway Track Champion.
2012 IHRA Div. 5 No-Box Champion.
88 career wins.
soldmy72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soldmy72 Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2017 at 2:16AM
They look similar to Crites.The angle is what gives the 3/8" height difference
72 GTS Q-auto...sold
73 'Chero Q 4 spd
72 GTS H-auto
72 GTS Q 4spd
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordismyboss Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2017 at 4:18AM
I'm running Factory CJ manifolds and stock CJ oil pan.
Yes, wanting to use stock mounts but concerned about the high torque numbers(540). The '72 429 was rated at 205HP, torque?. I'm thinking if I beef up the stock mounts, design-in an anchor on each mount and a torque bar on the driver side, that might be better(?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2017 at 11:43PM
Those look like they are a fullsize mount with a fabbed frame bracket.  As long as the engine is located correctly, they are fine. Lower bracket ears look odd, but they were made angled to allow access to the mount-to-block bolts. As far as them being Crites... No, probably D.I.Y., although some of the early Crites lower mount brackets were kinda rough looking.
Your original mounts are plenty strong, but a torque strap is a good idea.
If you have '72 mounts, they revised the block plate in '73 to strengthen it.
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 01-March-2017 at 3:22AM
I run stock OEM mounts with a 521 big block and I haven't had any issues with the mounts yet.
-Billy Conturo
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 01-March-2017 at 7:46AM
Crites lastest mounts look rough as f**k as well.....they aren't worth the money they're asking based on the fabrication.....if I'd known how poor the welding was going to be I'd have suffered and made my own
Going to be removing them and using plates instead once I have some time and money
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordismyboss Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2017 at 3:53PM
OK, I'm going to run stock mounts with some upgrades. I'll post a pic when I'm done with them and see what you think. Thanks!
Edited by fordismyboss - 06-March-2017 at 3:23AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordismyboss Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2017 at 4:08PM
Here are two images of the stock 429 mounts with the side gaps now filled with urethane. Hope the stock rubber is compatible with 3M urethane! Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkGubinski Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2017 at 2:16AM
I used urethane before I went to the motor plate. It worked for awhile. Hope you used to primer. Make sure to use a torque strap.
88 career wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 09-March-2017 at 12:15PM
You can also drill those in the center and put a bolt thru to hold them together but it will transmit more vibration to the chassis.
