  New Posts New Posts RSS Feed - 460 engine woes
460 engine woes
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: 460 engine woes
    Posted: 04-May-2007 at 5:40AM
Hey gang,
A friend was out hot roddin his 460 Torino around and developed an engine problem. He was doing several smokey donuts when all of a sudden the engine quit and wouldn't restart. He said the coil was very hot and had no/weak spark. My initial thoughts are the ignition module has gone south. Don't know if it's it has been replaced or if it's still original.
What are the thoughts of all the engine gurus on here?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2007 at 5:47AM
Hey gang,
Turns out it was a distributor drive gear that had lost a few teeth!
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2007 at 3:17AM
Your friend should go through the engine then and possibly replace the cam.  If the cam ate the drive gear then there may be other problems and metal in the engine..  I'd still look at the module and the coil as well.  If there is metal in the engine, then the next time it may be a spun bearing or worse, and a smokey burnout ending in a blown motor may be heroic, but very depressing as well..
Just some thoughts,
Jim
1976 S&H Gran Torino
460/C6/4.33 13.05@105.6
545/C6/3.56 11.52@117.8
More to come!!!!
463rwhp/495rwtq
two tons of fun
see it and hear it at:
www.torinocobra.com
www.st
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2007 at 5:02AM
Thanks Jim, I'll pass along the suggestion!!
yatomjones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yatomjones Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2007 at 10:01AM
I have 69 Mark III with 460 (of course). Can anyone tell me merits of this engine- a friend says should hav e good stuff- forged rods soid lifters, etc.
starsky76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote starsky76 Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2008 at 12:37PM
I don't believe that came with a 460,460 wasn't avaiable in 69.you could get a 429 in 69,thats the biggest.If its a 460,someone swapped it in.No forged rods,no solid lifters,probably a smogmotor.Good one for a fresh rebuild.That motor stock maybe 260-280hp built for torque to move that heavy lincoln.
