460 engine |
Author | ||
72RogerGT
Senior Member Joined: 20-September-2013 Location: Maricopa, AZ Status: Offline Points: 233 |
Posted: 02-September-2014 at 8:08AM |
I just found a 73 460 amf trans for a really good price. Do any of you guys kno if this engine would be able to make decent power or should I stick to and older engine. Thanks.
aquartlow
Nothing wrong with the vintage of your 460, just about any 460 can be rebuilt to deliver good, reliable power. There are some 429-460 parts that are better or more sought after, but even a "run-of-the-mill" 460 with a "good" complete rebuild can be fairly potent. Do you see any casting #'s on the heads, block and intake? What kind of power numbers are you seeking?
GranTorinoSport
Any 429 or 460 in good condition will be very good. If you are looking for tip top performance then some parts will matter.
Webmaster |
72RogerGT
It's a d3ve block and nothing crazy however I kno that most of the time everyone is looking for a d0ve or dive block and heads. So just wondering if it matters at all or not I can get a hold of a set of d0ve heads but idk yet of it'll make a difference. Thanks guys.
aquartlow
Head casting numbers/design will make a difference in compression and/or piston selection to get them "most" out of them. This should help with the 429-460 head casting # differences:
Lots of good info/knowledgeable folks on 460Ford.com to assist with almost any BBF questions. Hope this helps. Todd
Billy C
Senior Member Joined: 10-February-2010 Location: Pittsburgh, PA Status: Offline Points: 947 |
What are you expecting to get out of it? Not necessarily hp but intended use is a big thing too.
-Billy Conturo
72RogerGT
Thanks todd. They do have a lot of useful information. I bought the engine and it seems to be in decent condition. I also got a c6 trans with it, both seem to need some tlc. Either way I plan on rebuilding both. Billy I plan on using it as weekend driver yet I want it to have decent hp. I think as long as it is in the 300 hp to 400 hp range I'll be happy. I have access to a pair of d0ve heads. The engine currently has d3ve heads, do you guys think I should get the d0ve heads? Thanks for your input I need to get more info about the 460 engines.
aquartlow
IMO, I would choose using the DOVE heads(closed chamber, screw in rocker studs and usually no EGR ports) over the D3 heads, both will work fine and have/give plenty of power/reliability, just have to figure out what compression ratio your target is and select the piston that is right for each head. D3 heads usually have induction hardened exhaust valve seats to help with valve seat erosion caused from the use of unleaded fuel, though usually most of this induction hardened area is used up when a valve job(regrinding the valves/seats) is performed, so either leave the exhaust side alone or new hardened exhaust seats will be required. DOVE heads have no hardened exhaust seats from the factory, thus require the extra machine work costs(usually $150-200). To be honest it would be best to perform this process to either of these heads due to age, previous usage and/or intended use. Good luck, Todd
gnrlee01
Senior Member Joined: 04-August-2013 Location: iowa Status: Offline Points: 345 |
thanks for the link above. i didnt get it to open till after i posted this. :P
Edited by gnrlee01 - 03-October-2016 at 9:09AM |
gnrlee01
ok, ive got a question that i need everyones opinions about. i bought a dragon fire hei distributor for 60 bucks to go on my torino. does anyone have any experience/knowledge about this particular manufacturer or distributor? are they any good, middle of the road/average, or crappy? and was the price low, fair or high?
never heard of it but everybody and their brother are making HEI dist. for most engines these days! is it like a GM style HEI?
gnrlee01
yes, its like a gm style.
what is the one that you have on yours and how much did it cost you? Edited by gnrlee01 - 30-October-2016 at 8:52AM |
gnrlee01
what hei distributors do you guys have and how much were they?
foote500
Senior Member Joined: 13-June-2011 Location: Winchester, VA Status: Offline Points: 1267 |
Piggy backing off of this, I am so tired of trying to deal with the Clevelands, if this engine goes back, I might have access to a 68 249, maybe I will go over that and drop it in. I have read the site listed up above, but does any one want to offer an opinion on the 68's?
Marc
German Shepherd Rescue 1967 Ford Fairlane 500, 390 |
Nuggets
Will drop in as I have a 69/70 - 429 in my 73, need Crites mounts (but they're built like sh*t, buy them, copy them, send them back) I'm going to be selling mine and making motor plates up instead.....
Will need big block C6 as well, bolts right in though 68 should be a D0VE or C9 block with the same heads, I have D0VE-A block with the upgraded Boss 429 bulkhead and D0VE-C heads, using the Mercury Marquis manifolds it fits in but obviously needs custom downpipes
Barnaby
429 powered 73 Stripper.....no comfort, just noise! |
MrSmog
"D0" = 1970 . a 1968 429/460 engine will have a "C8" block and heads.
Edited by MrSmog - 04-May-2017 at 1:53AM |
foote500
It is a C8VE, I have a C6.
Marc
unlovedford
I have the D3VE heads currently on my gold '72 460. It runs very well with them, a healthy cam/lifter/spring/timing set, intake manifold, truck manifolds. However, I bought a set of D0VE-C heads for it that should wake it up and will be adding more carb and a set of headers in the future. The D0 heads are much better heads, but the D3 work pretty well with a warmed-over 460.
500HPTorino
New Member Joined: 06-October-2015 Location: Germany Status: Offline Points: 11 |
If you are going to do a 385 series block (429-460) I would recommend the 460 truck short block with 429 DOVE heads. the stock lower end with ARP rod bolts and Main studs will take 750 hp. I would also change the pistons to a forged. slight dish. It will bump up the comp ratio from 8.1 to 10.5. comp cams makes a lot of good cam's for that block.
It can be removed and replaced with useful parts, but that's just more parts you have to source. They were all originally built for leaded 93 octane gas, so valve seats aren't hardened, and pinging is almost certain. You can dial back the timing and de-tune, but...again, right answer is a rebuild with appropriate parts for today's fuel. |
aquartlow
Yep^^, they also use a different style water pump and pulley's with different "offset" dimensions as compared to '70 and up 429/460's.
unlovedford
We were having this exact conversation this weekend at SRN.
FWIW i don't see any issues 351C specific, just general that can / do & will happen working with any platform
