  New Posts New Posts RSS Feed - 460 VIN location
460 VIN location
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: 460 VIN location
    Posted: 26-February-2016 at 5:00AM
Guys,
I found my VIN number on my C6 but can someone advise where the VIN would be stamped on the 460??
THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2016 at 5:33AM
The early model 429-460's had a ID tag very similar to a Ford 9" ID tag, here:
located under the front DS intake bolt, next to the ignition coil mounting location.
I found a couple of these engines when pulling a set of DOVE-C and C8SE 429-460 heads.
This shows where it would be located on an early model Ford truck with FE engine:
The newer models('72 or '73 and up) used the valve cover sticker as the engines ID/VIN for the vehicle that it is installed into. Hope this helps.
The block, head, intake/exhaust manifold numbers aren't VIN numbers per se, only date code and casting/production numbers. There are many, many big block parts with D_VE casting numbers used for Ford/Mercury intermediate engine parts, even though the "V" designates the parts where produced for a Lincoln.
Edited by aquartlow - 26-February-2016 at 5:46AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2016 at 5:42AM
Thanks Todd, I know it's a 460 but was trying to determine if it's my Torino's original engine.
mtburger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtburger Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2016 at 6:34AM
The partial VIN's are located on the drivers side, rear of the block, just underneath the cylinder head.
There is a small flat pad there where they stamp the partial VIN on.
It will have the year, the plant, and the consecutive vehicle number only.
The attached example is a 70 429 block from Lorian, and because the first digit starts with a "5", it was used in a Mercury, Lorian was an "Intermediate" facility so it most likely was in a Montego or Cyclone I believe.
Mike H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2016 at 7:12AM
Thanks Mike, I'll have a look at mine.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 28-February-2016 at 10:06AM
WOO HOO.... found it. Mine's a number matching car!!!
Edited by TV 2M8O - 28-February-2016 at 10:07AM
