  New Posts New Posts RSS Feed - 460 w/ Victor Manifold - Water Pump Hose Routing?
Ron Earp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Topic: 460 w/ Victor Manifold - Water Pump Hose Routing?
    Posted: 23-January-2011 at 1:24AM
I've got a question about using a Victor manifold and Edelbrock water pump in an application that requires a heater core as well as a temperature sending unit.
I've attached a diagram that essentially labels all the ports. A & B are on the manifold and C & D are on the water pump. B is supposed to connect to C as a thermostat bypass (I think, not sure). A could then run to F, the heater core feed, and then E to D as the heater core return.
However, that leaves no place to screw in the temperature sending unit.
Questions:
*Is the B/C connection the thermostat bypass? If so it seems large.
*Would a 1/8" hole in the thermostat enough of a bypass for the system? Seems to work for many cars.
Or, do I have it all wrong and it works like this:
C supplies the heater core
D is the heater core return
A can be plugged
B can be used for the temp sender
If what I wrote above is correct then I'm good to go.
I can also pull the manifold and tap a hole back on the back side of it to get access to head water, but I'd like to avoid that if possible.
04 Ford Lightning
72 GTS BB Stroker & Toploader
98 Mustang ITS SCCA #38
08 Buell Ulysses
GT40s.com
Blueoval76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2011 at 4:37AM
Ron your original statement at first is correct on how it works.
All you need is one of these...
03 Bonneville some mods
