  New Posts New Posts RSS Feed - 460
460
GRAN1976TORINO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GRAN1976TORINO Quote  Post ReplyReply Direct Link To This Post Topic: 460
    Posted: 18-August-2008 at 3:13AM
what year did the 460 begin production?? i have heard 74.
PatsPOS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatsPOS Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2008 at 5:30AM
Well, that's partly right...the 460 found its way into Ford cars and trucks in '74 (MIGHT be '73 for the trucks...I'm not sure).  But the 460 started life in '68 in the Lincoln Mark III and possibly the big Lincoln, too.
Pat
'75 460 Gran Torino Sport (14.04 @ 97 MPH)
'91 Crown Vic (18.09 @ 75 MPH)
'89 300 F-150 (18.37 @ 73 MPH)
Post Options Post Options   Thanks (0) Thanks(0)   Quote GRAN1976TORINO Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2008 at 2:24AM
thanks!
interceptor460 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote interceptor460 Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2010 at 7:02AM
 The 460 was also used in fords 1973 only as a 460 pi package. If you find one it is a good start for a performace engine.
albo74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albo74 Quote  Post ReplyReply Direct Link To This Post Posted: 14-March-2010 at 10:53PM
73 was the last year of the 429, so 74's had the 460 A code and the C code was for law inforcement only, Interceptor460, I have got a 460 with about 4thousand miles on it. and I am toying with the idea of putting a mild, or cj type cam in it,and replacing the intake so as to get a bigger carb ( it's smaller than my 351)  the car has all the right options , locking 3.25 rear auto buckets ect.. but the 215  a code is just a little to numb. If you had this car as a platform, what would you do to the engine , to bring it up to speed , short of pulling it out of the car? Keep in mind that I want the car to look stock and would only want availible at the time  c code  or cj options ?
albos74gts
Post Options Post Options   Thanks (0) Thanks(0)   Quote interceptor460 Quote  Post ReplyReply Direct Link To This Post Posted: 16-March-2010 at 6:35AM
i
Post Options Post Options   Thanks (0) Thanks(0)   Quote albo74 Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2010 at 10:27PM
To make a stock  460 run cooler can I just run a 180 degree  thermo  , ( some guys add electric fans) ,  then add extra oil, and an oil cooler?  the water is top end and the oil is bottom end, for engine protection right?  they make a lower temp thermo than 180?
Edited by albo74 - 19-March-2010 at 10:39PM
albos74gts
Post Options Post Options   Thanks (0) Thanks(0)   Quote interceptor460 Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2010 at 4:03PM
On my 460 I had a stainsteel flex fan rated to 8000rpm and a 4 coe rad with 160 degree thermostat. The fist time I ran a electric fan was on my 68 ltd with 428 in her ,the only reason I did not run a electric  fan on the 460 . Was the early models ( electric fans ) drain alot power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote interceptor460 Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2010 at 4:20PM
The correction 4 core rad and the early electric fans needed alot of amprage . They tended to drain down the battery.
This page was generated in 0.328 seconds.
