Forum Home Forum Home > Model Specific Forum > Other
  New Posts New Posts RSS Feed - 4.6v8
4.6v8
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: 4.6v8
    Posted: 18-May-2017 at 7:11AM
before I go on line were are the spark plugs. I know its electronic ig. buy I can't even find wires.
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 7:49AM
4.6 2v and 3v have coils running down the engine at the top edge of the valve covers.
4.6 4v has covers dead center of the valve covers with the coils and plugs under them.
Sal Mennella
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 11:43AM
Ever seen one of the 1960s GMC V6 with the spark plugs in the intake side of the heads? 4.6/5.4 are in a similar location. They are at the top of the valve covers, by the intake/injectors, not down by the exhaust, under coil-on-plug units or with little plug wires leading to coil packs. If this is in an F150, they are mostly under the cowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2017 at 5:44PM
randy, yeah back in the day i've worked on a couple of those GMC V-6's i think they were a 305 ci.? coffee can sized pistons yeah those plugs were between the intake runners like 7.3 glow plugs!!
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 12:29AM
So I am not crazy just need to look closer it is a f150.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 4:40AM
you if it's coil on plug (COP) you need to remove the 8 individual coils to access the spark plugs
and be very careful when you tighten the plugs back in. not too tight not too loose, just right!
actually the tricks start before you even remove the plugs, on a warm/hot engine i would gently tighten each plug first before i try to loosen it. this'll break any tension/seizure that might be in the threads
here's not too bad page on the subject
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 1:50PM
I love my fords but why do they always have a better idea. Did research damn I was right no spark wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2017 at 3:12PM
Be so careful with the plugs. I cannot stress that enough. Liberal use of penetrating oil around them overnight, crack them loose with an impact set to it's lowest setting, and carefully remove them. Hopefully yours are not the 2 piece plugs and you have the revised heads that contain more threads.
1972 GTSquire Wagon
1976 Torino (2)
