  New Posts New Posts RSS Feed - 4bbl intake on 2v 351w
74GranTorinoSport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Topic: 4bbl intake on 2v 351w
    Posted: 31-March-2021 at 12:15PM
I have a weiand stealth intake for a 4 barrel that I want to put on my 351w 2v, were the heads the same for 2v and 4v 351w in 1974? I’ve heard Clevelands were different but can’t find any solid info on 351w in 1974.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2021 at 12:58PM
IIRC, there were no 4 barrel versions of 351W's in '74, From what I understand even the 2V and 4V 351W of the late 80's early 70's used the same head, a 351C had head variations for use on 2V and 4V engines, if you have seen or saw the intake port differences between a 2V and 4V 351C you will know it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2021 at 2:24PM
351C-4V, 351C-2V and Windsor
Rons73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rons73 Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2021 at 5:07PM
Should fit no fuss!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2021 at 8:23PM
no problem! only difference is 74 and earlier heads used a 16 bolt intake later ones only used 12 of the bolts but do fit the same...
offenhauser 16 bolt intake note the extra bolts at the water crossovers...
Rare Dual Port Spread Bore Offenhauser Offy Intake Ford 351w Mustang Cougar F350
later 12 bolt intake
Small Block Ford 351W Satin Aluminum Intake Manifold  Dual Plane
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2021 at 2:44AM
Those look like big port Windsor heads, maybe 180cc, similar to what most popular aftermarket heads are now.
The 4V Cleveland heads are over 240cc ports, I'm not sure what the 2V head port sizes were.
