4-Speed Flywheel Starter trouble |
fordsplus
Brand New Member Joined: 16-June-2016 Location: Michigan Status: Offline Points: 2 |
Posted: 16-June-2016 at 9:33AM |
I have a 1971 Torino with a 1971 429 engine I also have a toploader an 11" clutch with a 164 tooth flywheel. Can't seem to find the right match up since the starter doesn't make contact with the flywheel. What am I doing wrong can someone tell me the correct set-up for my issue??? Thanks!
torinojon
Senior Member Joined: 07-February-2013 Location: AZ Status: Offline Points: 474 |
you just put this together.wright.if this is all new i think you got the wrong fly wheel.it needs to be i think 176 tooth flywheel... .
torinojon
are you running the bb 429 cj bell housing or the 351m/400 bell housing.theres diff flywheel per bell housing. 176 is 429 cj bell big input tranny housing.the 351m/400 is truck bell housing small input tranny.i dont no the tooth count for that flywheel.i think i got one...
Edited by torinojon - 06-July-2016 at 4:01PM |
Billy C
Senior Member Joined: 10-February-2010 Location: Pittsburgh, PA Status: Offline Points: 947 |
I have a 176 tooth flywheel in the T10 400/351m bell housing and use a starter for a 1992 F series 460 truck with M/T. I use two washer (.125) to space the starter back so the teeth disengage all the way.
-Billy Conturo
